I just purchased this device to use with DMD2 (Thank you BTW). It is working well so far the cost of the device is pretty reasonable and if you set it up as a dedicated device (not a lot of apps loaded) it performs very well with DMD2. I also created and shared a mount I designed to put this on the Yamaha T7 Tenere I case others are interested. It can be downloaded from printables https://www.printables.com/model/860720-yamaha-t7-tenere-umidigi-x20-mount/files
The screen size is just right for me on this device, plenty large enough but still fit behind the Tenere wind screen just barely after the case. I’ll post back if any issues arise after testing in summery heat, etc… So far so good though. It made it through the first really wet test ride without any issues.
