Tagged: aprilia, HEX ezCAN, installation, Tuareg, Tuareg 660, wiring
I am new to this group and I am planning on purchasing one of the DMD navigation devices for my 2024 Aprilia Tuareg 660. I like to plan ahead and visualize the install and therefore I am asking for folks with the same bike to share their installs and advice in this regard.
Some of the goals for my install include that the unit turns on and off with the ignition, does not mess up the bike’s electronics, is waterproof or water resistant and that the wiring is run neatly as to not interfere too much with repairs and servicing. I may have to deviate here and there from these goals, so please post your comments even if your setup does not fulfill all of these criteria.
Two specific questions I have right now are:
1. How to connect the DMD-navigation device to HEX ezCAN
2. Where to tap into an ignition switched wire for connection of the green wire if I do not use an EZ-can
Thank you
