I just wanted to say thank you to the developers. This software is really well thought through. I still have work to do for the controls I want to setup, but so far I have offline maps, obd2, and roll charts all work really well. The design and layout is just really well thought through. I did notice one bug where I had to completely reset my device. It only happens though if you load a lot of GPX files all at once. I’m sure the device ran out of memory but once it happens there is no way back outside of a full reset. This happened because I saw the feature to load the GPX files and hide them. So I thought why not load all of my files then just turn them visible when I want to use them. It wasn’t clear to me that adding them would consume resources. Also the “delete” of the GPX made me nervous, I wasn’t sure if it was deleting them from DMD2 or from the device. It does only delete from DMD2. So with that learning curve out of the way, I’m up and running. Thank you again, this is really an amazing software and I hope the ecosystem around it stays open. It is unfortunate that I had to buy a dongle for the T7 even though it came with a blue tooth dongle, but I understand trying to support every mfg would be a large effort.
