Viewing 10 posts - 21 through 30 (of 33 total)
  • #5544
    Luis
    Suzuki VStrom 1050XT
    OBD Scanner M1 DMD2
    • This reply was modified 8 months, 2 weeks ago by Luis.
    #5604
    Jan
    Someone tried to make a test with ktm 990 adv. 2009 to 2012
    #8337
    stazione69
    Qualcuno ha provato su Honda Crf1000L Africa Twin 2016?
    #9407
    Grant McFarlane
    Works on 2023 Gas Gas ES700
    #9409
    Ioannis
    It works fine with my Suzuki V-Strom DL650 2023. I’m sure it will work fine with any third-gen model from 2017 onward.
    Fuel level and Mass Air Flow are not working. I think these are not properly reported by the ecu.
    The throttle position starts from 21% but this value is coming from the ecu directly. So, I just use “Calibrate Throttle Position” from the settings and it works fine.
    Tested with OBD Scanner M1 DMD2 and ELM327 mini.
    #12197
    Bernhard Conrad
    Not sure if it has been discussed or not. Is there a chance to display on KTM690 Enduro R Euro 5 the current selected gear ? Or is this information not available in OBD ?
    My Tablet in the way as it is mounted is hiding/covering the speedometer cluster and it would be great to have the selected gear replicated in the DMD2 dash.
    #20619
    Mike Hayes
    Confirming that both 2023 Husqvarna Norden 901 Expedition and 2022 Husqvarna FE350 both work with OBD Scanner M1 DMD2 using the red EU5 cable
    #20847
    Stegi
    Works with a Ducati Multistrada V4 Rally 2023, except fuel level.
    #20849
    Stegi
    It seems not to work on a KTM 690 Enduro R 2014. It only shows the voltage of the dongle.
    #22023
    Jay
    2023 KTM 690 Enduro R works.
