9 November 2022 at 12:48 pm #762Ianm003Participant
I am using the DMD2 App on a Samsung Tab Active 2. As the Tab has a small memory capacity I have been moving all apps to the SD card to free up space.
I’ve found that both the DMD2 App and the TET App are not compatible for storing to the SD card, from a bit of research I believe it is down to the App developers to “Allow” this option, and no doubt there maybe technical reasons for not being able to do so.
However, if this option was available it would be very useful especially when downloading maps & tracks from both DMD2 and TET.
Or, have I got this wrong and others have managed to do it?
9 November 2022 at 1:25 pm #763João PereiraKeymasterHello
TET Tracks are GPX files, they are VERY small.
DMD2 app is also rather small so the problem is the offline maps. If you format an SD Card as External Storage (Removable Media) you can go to DMD2 map view, push the LEFT Menu, click on Map Options and there an option to store map files on the SD CARD.DMD2 Project Manager & Lead Developer
Buy Me a Coffee9 November 2022 at 1:31 pm #764Ianm003ParticipantCool, I’ll take a look. Is this also a similar process with the TET tracks?
9 November 2022 at 1:57 pm #765João PereiraKeymasterCool, I’ll take a look. Is this also a similar process with the TET tracks?
As i said, the TET Tracks is just a GPX file, it is really small, usually bellow 10Mb…
What you are concerned is the offline maps that are usually above 1GB.DMD2 Project Manager & Lead Developer
Buy Me a Coffee17 March 2024 at 3:35 pm #4309AxelParticipant@johnkeel just review this thread as I encountered the same Problem setting up DMD with an external SD card on my Samsung Active 2 tab. I did reformat the SD several times. It does appear in setting not being part of any internal storage. Nevertheless I don’t even see/find an option to store any map on an external storage. Also did also look for the option to enable external storage in general setting but it’s not even there. Attached two screens that show what I do encounter. Please help 🙂
17 March 2024 at 5:34 pm #4310AxelParticipant@johnkeel this is the screen were I can’t find the toggle to enable saving data to external. But I believe it should display there. Any thoughts
20 March 2024 at 1:46 pm #4341João PereiraKeymasterHello
We cannot access the SD Card anymore, google changed the way it works and we cannot get the permission for it.
Only our devices have access to it because our devices do not rely on Google Play Store for DMD2.- This reply was modified 10 months ago by João Pereira.
Buy Me a Coffee9 May 2024 at 12:15 pm #5599Koos BoersmaParticipantHello,
I have the same problem. Is this going to be fixed?
Regard Koos
9 May 2024 at 12:42 pm #5600AxelParticipantI did change to another unit. Bought a OUKITEL WP23 with enough memory which works perfect for me instead of dealing with the Samsung issues
