  • #21853
    BJHawker
    Hi, I updated my DMD2 version in order to solve my downloads problems, unfortunately on the stock install some buttons, including the home and navigation are missing.
    Did someone experienced this problem ?
    #21855
    Hi, I updated my DMD2 version in order to solve my downloads problems, unfortunately on the stock install some buttons, including the home and navigation are missing. Did someone experienced this problem ?
    That is a weird one indeed.
    Can you double check the app version?
    Are you sure that you cant just drag that list up and down?
    BJHawker
    The version is the 3.00149 and it is installed on a Galaxy Active Tab 3 (SM-T575 Android v13 OneUI 5.1.1). Prevently, I saved my profile and by restoring it, the buttons reappeared, and, and, the failed downloads :-(…
    But, but : I removed the dmd2_downloader_database* filed from the saved archive and now, everything is running fine…
    If you want some more tests to improve the software, let me know, I would be glad to help you. As my configuration could now be completly erased I can test what you need…
    • This reply was modified 2 months ago by BJHawker.
