Hello,
I hope I’ve come to the right place. I am using a Samsung Galaxy Active5 Tab (Android 14) with the DMD2 software.
I have recently installed the Silverfox B8J (firmware B8J_Button1.1). The installation of the Button.app worked. The controller also works. However, I get an update message almost every minute (“Whats New: T665 Button configuration”). If I confirm the update, the app crashes immediately, if I tap on later, the update message appears again after about 1-2 minutes.
Is this a known problem? Am I alone with this? What can I do?
I hope someone can help.
Sorry about this, will do some more testing on Android 14, for now please update the app manually by installing the apk again:
https://drivemodedashboard.com/dmd-controller-app.apk
Thank you. Works fine now.
Hi
I have a Samsung tab active 3 and Android 13. I have installed the buttons app, but it doesen’t show up in apps so I can allow it to run properly.
B.O.
