  • #36685
    Bigfoot
    Currently on the tablet in DMD2 map view, once you’re away from the track for more than a couple of hundred meters, the navigation aids stops showing where the next point is. One used to be able to set the distance before this happens, but that does not exist anymore (or I can’t find it). I’d like a feature where you can set it for condition of outside of urban areas as well as for inside urban areas. In a city, being away from a set track for more than 10m is a problem. On an off-road track, one needs to pick your distance, up to 1,000m might still be OK. Can you please add this functionality?
