  • #4337
    Riebli
    I use a 128 Samsung evo Plus SD card.
    It has been formatted in the device and is displayed correctly.
    in dmd, storage on SD card has been selected.
    Card can be downloaded correctly on SD card.
    it all works great, but when the T-865 is rebooted, the
    the following message and persists for more than 20 minutes.
    SD card is mounted
    Please wait for the SD card to finish mounting……
    Cancel & use internal storage
    If I now cancel and activate the storage location again on SD card under the settings, it runs again.
    my device is a T865
    Build No. mdt865_ngms_1.9.0
    DMD2 ver 3.00046
    Greetings from Switzerland
    Klaus
    • This topic was modified 12 months ago by Riebli.
    #4339
    Riebli
    Now it works again.
    What did I do?
    Device reset, all set up again.
    Now the message comes only a few seconds
    so everything is fine and I’m looking forward to various tests
    Greetings Klaus
    #4340
    That is a known Android bug.
    When an app is set as default home app and the system starts without the SD Card being mounted before the app starts it can cause that.
    For that reason, when using an SD Card i do not recommend using DMD2 as the default home app.
    Riebli
    Thank you very much
    I’m more from Apple, I still have to familiarize myself with Android a bit.
    Greetings Klaus
    • This reply was modified 12 months ago by Riebli.
    #34439
    DavidE
    So what’s the fix?
    This just happened to me… it’s been working fine and all of a sudden I have this problem.
    i run DMD as the default app.
    i have no map displayed but it shows a location, I’m at home, so it has “home” symbol snd a blue location icon, but no actual map data… when I select the Apps symbol I get this same messsge. Been staring at it for 20min no change.
    is the card corrupted and I need to buy another card and reload all my maps and GPX routes?
    I’ve tried once hitting cancel, switch to internal storage, then switching the selection back to the card, but same issue…
    What’s the fix?
