2 July 2024 at 11:22 pm #7547
Roland
ParticipantThere is a problem when editing total/partial distance field. It is not accepting the edited value.
2 July 2024 at 11:23 pm #7548Roland
Participant2 July 2024 at 11:24 pm #7549Roland
ParticipantAlso the altitude digits are not displayed correctly.
4 July 2024 at 2:22 pm #7561João Pereira
KeymasterHello
Just tested here and it is working. Make sure you do not have a distance multiplier set:
– Click the cog wheel in the Roadbook view, scroll down until you find “Distance Multiplier” and tap on it. To “disable” it set it to 1. -> I need to improve this dialog and add a “Reset” button.DMD2 Project Manager & Lead Developer
Buy Me a Coffee4 July 2024 at 2:23 pm #7562João Pereira
KeymasterAlso the altitude digits are not displayed correctly.
Indeed thats a bug, will fix it.
Buy Me a Coffee4 July 2024 at 2:45 pm #7566Roland
ParticipantI need to set a distance multiplier because of a slight deviation from the GPS regarding the Roadbook mileage. I think this should be independent of the edit partial/total distance. In other words, the distance multiplier should not affect the partial/total distance editing. Just my 2 cents
5 July 2024 at 9:28 am #7572João Pereira
KeymasterI need to set a distance multiplier because of a slight deviation from the GPS regarding the Roadbook mileage. I think this should be independent of the edit partial/total distance. In other words, the distance multiplier should not affect the partial/total distance editing. Just my 2 cents
Yes it should, and i added it to the TODO list…
Buy Me a Coffee5 July 2024 at 10:47 am #7574Roland
ParticipantThank you. Next week at Bosnia Rally
12 July 2024 at 4:23 pm #7686João Pereira
KeymasterThis is now fixed:
DMD2 3.00084 released:
– Roadbook Edit Instrument values now take in consideration the measurement correction factor
– Roadbook Measurement Correction Factor dialog now includes a reset button to go back to x1 (no correction)
– Roadbook Instrument 3 – Fixed a case of double value overlay (usually a sticky “0”)
– Roadbook now supports files with password – User will be asked to insert password
– GPX Recorder on save now shows a file generation progress dialog, a lot of users complaining about lost GPX recordings were because while the GPX file was being generated in the background they closed the app, now you can see the progress and wait for it to finish
– Added Hide Keyboard to missing dialogs: Recorder / Coordinates Insert / Places / My LocationsDMD2 Project Manager & Lead Developer
Buy Me a Coffee -
