At the moment you have to choose at least 2 data fields in the roadbook.
You can leave the third filed empty. But sadly the empty space is not used to increase the font size.
Please have a look at how you have solved this issue before the big update.
There it was possible to use fewer fields and therefore have a bigger font.
Thanks a lot.
Great idea ! I would support such a change.
Bump…
Is this still on the list?
Thank you very much.
At the moment you have to choose at least 2 data fields in the roadbook. You can leave the third filed empty. But sadly the empty space is not used to increase the font size. Please have a look at how you have solved this issue before the big update. There it was possible to use fewer fields and therefore have a bigger font. Thanks a lot.
When you have less fields the space you would gain would be vertical. To increase font size you need both Width and Height…
Can we please get at least the possibility to only display 1 datafield?
I only need one ODO.
The second field is confusing me.
At the moment I have to put black tape on the second field.
Thanks a lot
Greetings
