Viewing 10 posts - 21 through 30 (of 59 total)
  • #22209
    Thor
    What model year is your bike?
    Thor
    #22210
    Albert Lorinczi
    Hi, I have 1250 GS – model 2020
    #22330
    Thor
    Hello Esteve, i was going to send you PM, but I have to add you as a friend first, we can only message friends in here it seems.
    Thor
    #22495
    Bernie E
    Hello Esteve,
    are there many vibrations with the long one?
    Thank you
    #22502
    <p style=”text-align: left;”>Hi Stephan, no vibration at all.</p>
    #22507
    Jose Daroca
    Mañana intento hacerle una foto a un amigo que tiene en una Gs Adventure la tablet y se queda perfecta, ten en cuenta que la DMD T865 x no tiene bordes a diferencia de la Carpe y esto es lo que tapa la pantalla de la GS
    #22508
    Jose Daroca
    Ya veo que te han respondido, solo había visto la primera pagina, me ha encantado el mando, yo tengo una KTM 1290 SAS y le iba a poner el ARN Rally, pero este no me interfiere, me gusta
    #22834
    Charley Short
    Great information. How did you mount the DMD controller next to the Wonderwheel?  I had hoped to find a way to use the wonderwheel to control the t865 but I like your set up if the wonderwheel isn’t an option.
    #22930
    Hi Charley, I’ll try to answer you.
    To mount the Silverfox control, you have to move the rearview mirror a little. Just enough to leave enough space. I’ll try to find a photo of when I installed it, to show you.
    To use the BMW “wonder wheel” there is a CARPE-ITER option https://carpe-iter.eu/bmw-control/
    I didn’t like this option very much, because you have to use your right hand. (the same as for accelerating…) But it’s not a bad option. My biker friend uses it.
    With the Silverfox control you have to use your index finger, instead of your thumb, but you get used to it. And the truth is that when I drive I don’t move much through the different applications on the DMD-T865x Tablet.
    Although I have configured the physical buttons in such a way that I can start the apps that I use the most, and move between them.
    The configuration I have on the DMD-T865x is:
    I always start with the DMD app as Home.
    On the P1 button I have: Toggle Screen Touch.
    On the P2 button: Switch User App / DMD2 and as app Google Maps
    On the P3 button: Switch User App / Home (where Home is the DMD2 App) and as App, OsmAnd.
    This way I can switch between maps from the DMD, GoogleMaps and OsmAnd. Of course, I do have to physically press the buttons on the tablet while driving, although it is not a problem.
    The fourth application I use the most is TerraPirata, for roadbooks. But when I navigate with a roadbook I almost never leave that application.
    I hope, this answer can help you.
    #22931
    depending on the model of the BMW you have to be very careful not to pinch the cables of the “wonderwheel”
