  • #27789
    Stegi
    I’m using the Remotek One remote controller with a Blackview 9200 android device. While the arrow buttons on the Remotek controller are working properly, the plus and minus buttons don’t react as they should in DMD2. Instead of zooming in and out the minus button activates the Google Maps overlay and the plus button activates the function like long pressing into the map for marking a position.
    With other apps like Google maps or Calimoto the Remotek is working properly.
    Does someone know of this problem and can help with a solution?
    Thanks.
    • This topic was modified 1 day, 13 hours ago by Stegi.
    #27798
    Thor
    What firmware are you using on the remotek one?
    Did you set the remote detection to remotek one in stead of autodetect??
    What mode is the rmeotek one set to, if you are on the old firmware?
    • This reply was modified 15 hours, 59 minutes ago by Thor.
    Thor
    #27804
    Stegi
    Hi Thor,
    I am using the firmware version 2.0.0 on the remotek one.
    The remote detection was not on autodetect.
    Can there be a problem because I’m using also a DMD Remote 1 aswell?
    I even deinstalled and reinstalled DMD2 and the Remotek App but the problem is still the same.
    #27805
    Stegi
    Hi Thor,
    I just found out, that problem only occurs once the map changed into “Schwenkmodus” (I don’t know the English word for that). Before that all buttons are working properly.
