28 October 2022 at 2:47 pm #704
Sarge
ParticipantSo, I have the latest version 2.77 installed on an Active Tab 2 with a 128Gb SD card. I can down load your maps to the card but cannot open them in DMD2 without the Ap crashing, I just get the message “Ap Stopped Working’
I have the tab clicked in map settings to load maps to SD ?
Any advice would be appreciated
Sarge
28 October 2022 at 5:04 pm #706João Pereira
KeymasterWhat device are you using?
Does that mean you cant use the maps view? It crashes as soon as you open the map view?If so you need to clear DMD2 data or just uninstall and reinstall.
If you do so, can you please re-check that the crash starts to happen as soon as you set the SD Card as the destination for the maps?Thanks
28 October 2022 at 5:29 pm #721Sarge
ParticipantThanks for the incredibly quick reply John.
I am using a Samsung Active Tab 2, with the additional 128GB SD card. The issue happens if i save all maps to the card and then run the Ap, it just crashes. I have carried out at least 2 uninstall/reinstalls of the Ap, If I switch off the ‘save maps to sd card’ and then load them to the Tab memory the issue goes away, but i dont have sufficient memory to load what I need !
Sarge
28 October 2022 at 5:58 pm #722João Pereira
Keymaster[quote quote=721]Thanks for the incredibly quick reply John. I am using a Samsung Active Tab 2, with the additional 128GB SD card. The issue happens if i save all maps to the card and then run the Ap, it just crashes. I have carried out at least 2 uninstall/reinstalls of the Ap, If I switch off the ‘save maps to sd card’ and then load them to the Tab memory the issue goes away, but i dont have sufficient memory to load what I need ! Sarge[/quote]
What Android version is it running?
Is the SD Card formatted as “Removable Media” or as “Internal Storage” ?1 November 2022 at 9:17 am #730Sarge
ParticipantHi John,
Sorry for the late reply.
My device is using Android 7.1.1 and the SD card was formatted for internal storage.
Regards
Sarge
2 November 2022 at 9:18 am #731João Pereira
KeymasterIf it is formatted for internal storage then DMD2 does not have any way to know its an external card.
When you have it formatted as internal storage you should NOT enable the “Save to SD Card” option, this option was designed only for removable media SD Cards.2 November 2022 at 3:35 pm #732Sarge
ParticipantThank you for the reply John,
I will re format the card and change the setting.Best regards
Sarge
12 January 2023 at 11:13 am #831lance201
ParticipantHello,
I have the same hardware,but Android 9. my as card is formatted as normal as card. And dmd will not use the maps if I download it on the sd card. I got a white map only. Do no crash but no use of the maps either. Any solution to that? The active 2 has not enough internal memory…
thx lance
30 May 2023 at 11:07 pm #2091fredrik.agne@gmail.com
Participant[quote quote=831]Hello, I have the same hardware,but Android 9. my as card is formatted as normal as card. And dmd will not use the maps if I download it on the sd card. I got a white map only. Do no crash but no use of the maps either. Any solution to that? The active 2 has not enough internal memory… thx lance[/quote]
I have the same problem. Did you solve it?
19 June 2023 at 10:43 am #2318voorstad
ParticipantI am having the same issue that in DMD2 (latest beta 2.99922) the option:
Storage
Set Storage to Removable SD Card
For offline map files and user files
Is greyed out. OSMAnd has no problem using the SD card (Android 9, SD card added as Removable SD Card).
I need to decide whether I will buy maps from DMD2 or from OSMAnd. Thanks for clarifying.
