  • #1318
    mp_
    Search is not working properly with Greek POIs names.
    Example: there is a store called “Αραχωβα”, if I search for the “αραχωβα” or “αράχωβα”, I’m getting POIs not found which this shouldn’t be happening as it’s the same word
    Searching for “Αράχωβα” returns some results but not the “αραχωβα”, so bottom line “Αραχωβα”, “Αράχωβα”, “αραχωβα” and “αράχωβα” is the same word and I should get results no matter how I type it.
    #1325
    Search is not working properly with Greek POIs names. Example: there is a store called “Αραχωβα”, if I search for the “αραχωβα” or “αράχωβα”, I’m getting POIs not found which this shouldn’t be happening as it’s the same word Searching for “Αράχωβα” returns some results but not the “αραχωβα”, so bottom line “Αραχωβα”, “Αράχωβα”, “αραχωβα” and “αράχωβα” is the same word and I should get results no matter how I type it.
    Today we are releasing 2.94 to Play Store, once you get that update please re-test this and report back!!!
    Thank you!
    mp_
    Today we are releasing 2.94 to Play Store, once you get that update please re-test this and report back!!! Thank you!
    DMD2 v 2.94, still not working as expected. Also the problem exist if I search the word, case sensitive, but selected from the phone auto completion, which adds a space at the end.
    ps. I try to reply with some attached images, but seems that I can’t, no errors just the post it won’t come up.
    #1335
    mp_
    DMD2 v 2.94, still not working as expected. Also the problem exist if I search the word, case sensitive, but add a space at the end, phone auto completion.
