13 July 2023 at 1:02 pm #2592Leopold SylvainParticipant
Hello,
Not sure i can really help you. In fact i could have bought any of the Evotech system as I am using only the lower part which is the same on all mounts.
Then, the tablet holder is a standard piece from Ram for 8″ tablets. In between I used bits from a Gopro holder I had and I hand made the rest.
This said, once in place, the tablet doesn’t look that big, and you get quickly used to the confort of the 8″ screen.
Tiger 900 RP
26 July 2023 at 10:43 am #2670edu732ParticipantHi.
I make these models for the oukitel tablet, one has a key to keep the tablet fixed, and another is with a hand nut. They are both very resistant, and they come ready for a 12 mm tube
- This reply was modified 1 year, 5 months ago by edu732.
- This reply was modified 1 year, 5 months ago by João Pereira.
22 August 2023 at 11:34 am #2669edu732ParticipantHello.
I make these supports for the oukitel RT3 tablet, both very resistant. one model is with a key, and another without a key.
6 February 2024 at 3:07 am #3882DingerJParticipantLate adder here but..
RT3 is great battery is a beast.
I also have ram mount 8″ It really doesn’t fit the RT3 correctly and with the help of some foam strips would be great. I may contact Ram Mounts as it would only require some new molded end pieces or some inserts. It just doesn’t fit great into the end caps and it can me annoys me.
I made my own adapter to the 12mm bar using a generic mount clamp with 4 holes and a 6″ piece of 2″ wide 1/8″ thick aluminum. Nice and solid.
6 February 2024 at 10:43 am #3883AirborneSilvaParticipantThanks for the input DingerJ.
13 April 2024 at 6:26 am #4436RonaldParticipantDear DingerJ
i have now also this tablet Oukitel RT3 and i am surching a holder for my bike.
Could you support me about pls?Thanks
Ronald5 May 2024 at 10:13 pm #5509mark-fishingParticipantBook marking this thread for updates.
13 November 2024 at 1:06 pm #22438PeterParticipantLate to the conversation but how do you find the screen brightness in very sunny conditions and do you have any experience on how it performs in high temp (35c plus) environments?
PD
13 November 2024 at 3:35 pm #22444Leopold SylvainParticipant<p style=”text-align: left;”>The brightness is ok, even under the sun, better, in any case, than the TFT screen of my Triumph.</p>
For high temperature, I went in Corsica, during the summer, with temperature reaching 35°, and I had no proble.Tiger 900 RP
16 November 2024 at 2:03 am #22504Rod McMahonParticipantLeopald
Sorry for the late question.. just found this forum
What power connection did you use… Looks like something waterproof into the USBC
Ronald
This may be of interest
https://www.printables.com/model/635116-oukitel-rt3-motorcycle-mount/files
