15 January 2023 at 10:03 am #833ThomasAT91Participant
Hi,
I downloaded several offline maps ( Portugal&Spain, France, Belgium Germany ) without any error during the download process. But only Portugal&Spain are visible. All other countries are not displayed. After one day even Portugal&Spain vanished. After rebooting the device (Carpe-Iter V4b) Portugal&Spain are displayed again, all other still remain vanished.
Any advice?
Thomas
16 January 2023 at 11:17 am #842João PereiraKeymasterIn the current DMD2 version the app will try to load only maps for the country where you are at the moment.
This can be changed, in the same screen where you download maps, after you download any map, there is a “Always Load” button right next to the download button.
If you enable the “Always Load” it will, as the name indicates, always load that map.If even after this a map is missing then you need to delete it and download again as it is probably corrupted.
For the next big DMD2 we changed this. EVERYTHING about the map layers is configurable so you will need to enable / disable EVERYTHING you want on the map, this goes for the offline map source, online maps or any other layer.
Buy Me a Coffee16 January 2023 at 6:41 pm #845ThomasAT91ParticipantThanks a lot for this information. That helps. By the way: is there a manual where you can read things like that?
Thomas
17 January 2023 at 9:34 am #846ThomasAT91ParticipantIn the current DMD2 version the app will try to load only maps for the country where you are at the moment. This can be changed, in the same screen where you download maps, after you download any map, there is a “Always Load” button right next to the download button.
btw.: what is the reason for choosing whether a downloaded map should be displayed or not? Displaying all downloaded maps is too costly concerning energy or processor time?
19 January 2023 at 9:41 am #847João PereiraKeymasterThanks a lot for this information. That helps. By the way: is there a manual where you can read things like that? Thomas
We are working on the manual, will be fully available in this website along with many tutorial videos.
As for the map load you are correct, the more maps you load at the same time the more resources it will use from your device. This will be even more important once we implement the POI search / browser feature…
Buy Me a Coffee9 May 2023 at 11:07 pm #1774davesahanaja@gmail.comParticipantHello, since yesterday I am a very happy owner of the DMD-T665 Nav Phone. I love the way it mounts on the bike.
I do have one issue though. Previously I used a samsung s20. On the samsung i was able to download most of the maps of europa. I was able to keep them all “loaded” and visible on the phone.
On this carpe iter DMD-T665 I am not able to load more then 3 maps. For instance, I live in the Netherlands. I go often to Germany. The moment i load the German map, the dutch map is blank. I find this very uncomfortable.
I did a test and downloaded the maps on the internal memory of the phone. All of a sudden I had the same experience as on the samsung. I could load most of europa and have everything visible.
Is it maybe the SDCard that’s limiting?
17 March 2024 at 6:40 pm #4312moeParticipantHey guys is there any solution for non loading maps in dmd?
I’ve downloaded them and set them button to always load. I do have network connection. (WiFi and cell)
just got 2 maps on my carpe iter right now.
Germany (currently at right now)
Spainso not too many maps I guess.
But still do just see the gpx data. Not the maps.
I’m going to Marokko next week so really appreciate your support.
Best26 July 2024 at 3:26 am #8219RsLParticipantYea I too am having the same issue.
I’ve downloaded and deleted many times now. Just one map only and still nothing showing. I’ve uninstalled and installed from play store and same every time.
Any assistance would be greatly appreciated
26 July 2024 at 9:36 pm #8227João PereiraKeymasterWhen reporting offline map issues please let me know the device maker and model and the Android version.
Usually maps not showing is a bad download, but there can be cases where you have too many loaded GPX files and the memory is close to full.
Buy Me a Coffee29 July 2024 at 3:46 pm #8237Arek KrakiewiczParticipantI had a same issue on my Samsung S21 and solution for that is to click Orientation icon (north oriented or travel oriented).
Than instantly offline map will appear 🙂
It’s a bug, should be fixed by dev team.Here is an icon you should click to show offline map if it’s not visible:
- This reply was modified 5 months, 3 weeks ago by Arek Krakiewicz.
