Hi there,
I am a novice using the DMD2 software on a samsung active 3 tablet. I downloaded all relevant offline maps on the 1 TB micro sd card that I use in the tablet.
However, when selecting/activating various countries/maps, the software switch goes back and the map is not loaded. Is there a size restriction? can that be solved in the setings?
Thank you for the help.
Hello which version of DMD2 are you using? New Beta or Production?
Same issue here. Just plugged in an SD card. Seem to help, although not set as the default… I´m on v2.77
