  • #12026
    NavCademy
    Hi folks,
    since the last update onto version 3.00113, or maybe one prior to that, the DMD2 application showed up an odd behavior – the Home Screen looks somehow weird.
    DMD2 - odd behavior - Home Screen
    I also recorded the power up sequence so that you guys get a better understanding of what it looks like. Due to the file size I uploaded video clip to WeTransfer – https://we.tl/t-79EkRzGBEY
    Thx and best regards
    Jan
    #12155
    This should be fixed on the next update.
    I would also recommend that you use screen lock option, it is in the Global Settings (Cog Wheel icon in the bottom menu) and then search for “Lock Screen Orientation” and enable it.
    raschaa
    As a workaround, if this happens switch color theme in global settings -> dark to light and back again to correct…
