I’m using an OBDLink LX dungle for my Triumph Tiger 800. I can run Tune Ecu and every thing is working good, but when I try to connect the DMD2 OBD it seems to be impossible. Do you how can I manage this problem ? I also try with the beta testing, still the same problem.
Best
Clément
What year is that motorcycle? Are you 100% sure that it is OBD2 standard? Usually OBD2 standard started being used on motorcycles around 2018.
It’s a 2016, and yes I am sure that it’s an OBD2.
Hi,
I have a 2014 Tiger 800 XC. It also has an OBD2 connector with the ISO 9141-2 standard. I have tried multiple OBD2 plugs and multiple apps, with which I can read out all info from the bike. The most successful has been Car Scanner.
When I try to connect the OBD module to DMD, it most of the times won’t connect. The one time it did connect, it showed the bike as having 1300RPM and 25% throttle, whilst the engine was not running.
Are there any other things I can try to troubleshoot or provide you with logging info?
