When you’re in the rider up view of the map-the rider arrow points up but the map rotates “below” as you ride- it would be nice for the rider view select button to change to directional arrow to indicate north as you ride. I’m on the beta so it may just be a work in progress still. Thanks.
Im sorry but im not sure I understood this, can you try to explain it better?
Thanks
I’m not sure I’ve totally thought it through, but in the rider view in the screen shot, when the rider arrow is up the map view pivots off the rider position. I was thinking it would be nice to either have the directional arrow in the upper left (circled in red with 1/2 the arrow painted red) indicating north while driving. The other option would be to show a compass rose with your indicated direction (like in the home view) on the right hand widget field (circled in magenta even though it may not be large enough). I know the degree number should be enough but it is also nice to have a quick reference for north.
