Viewing 5 posts - 11 through 15 (of 15 total)
  • #20843
    I have the same problem. Rode with KTM Adv. Rally the tracks in Portugal. Two days were fine until the 3 rd day it was worth. That seams to be big bug and never happened to me the 20 years before when I used Garmin devices.
    Were you using an SD Card?
    Pgsharpp
    I am facing the identical issue. Went on trails in Portugal with KTM Adv. Rally. The first two days were good, but it was the third day that made it worthwhile. It appears to be a significant issue that has never occurred in my 20 years of using Garmin devices.
    #21799
    Uwe
    yes
    #22106
    Pgsharpp
    Was the toggle trick successful for you? My device simply ceased to function after some time. Likely related to caching in some way.
    #22648
    Brian
    When maps do not load it usually means you have a corrupted file. Make sure you have the latest version of DMD2 and download the map file again.
    Yes, the maps were working fine on a Sunday ride, I got home and noticed a map update was available. I downloaded it  and all my map data was gone.
    I deleted the map and reloaded and it worked fine.
