  • #36465
    rme2thdr
    I have been unable to find a list of map symbols used in the DMD app, is there one?  If so, where can I find it, please?
    #36466
    TR42
    I don’t know of a “Symbols” list. Here’s the Legend for what the different road colors mean. https://www.drivemodedashboard.com/topo-map-legend/
    There’s a POI symbols menu in DMD that lets you choose to show/hide different types of POI on the map, that identifies what the symbol for each type looks like. Tap the Map Layers icon at the top of the Map screen. Next, In the left column scroll to/Tap POI Icon Highlight.
    #36610
    Well the map symbols kinda match the symbols for when you go to place search.
    Type the “Search-glass” round button on the map view, you will see a list of POIs which have almost all the same icons as in the map.
    rme2thdr
    Hello João,
    Thank you for your reply.  I did look at that list but was unable to find the legend explaining the different types of track until the previous response.  I’m sill not sure how I would find that explanation without using the link.
    A symbol that I have been unable to work out is a red circular dot with two white lines in it at right angles to one another, like the capital letter L.  I have seen these on the map spaced out in a chain, connected by black lines.  Do you know what these are, by any chance?
    With thanks in anticipation,
    Simon
    #36653
    Alistair Barclay
    Simon there is a  legend not complete but does help here, as a PDF file that you can load into DMD2 Roadbook. It’s in the file section of this Group Page.
    Green is good blue is no anything else with caution.
    #36665
    TR42
    I’m not finding a “file section of this Group Page”. Got a direct link instead?
    Thanks
