Hi. I’ve been searching for a setting but I find my lock screen always in portrait mode. My unit is mounted in landscape so it’s a little annoying to have to twist your neck while entering the pin code for the lock screen. Is there a setting to change this? I’m using the Carpe-iter Tab. Thanks
Each app has the power to set the available modes, for example, you can make an app and define it to only support Portrait, and in that case it will only be shown in Portrait, that is probably the case for the Lock Screen app, and in that case there isn’t much we can do since it is part of the Android system.
Thank you. Yes I understand this. It was just a matter of convenience
