17 June 2024 at 3:59 pm #7265Mikkel JørgensenParticipant
I’m having issues with what keycodes to use, I’ve read the page about costume controllers, but that only gives key code names and I can’t get any of the options to work completely
At this point I have this where only the Up and Down doesn’t work, and this matches with the HID Usage Table, however the UP and Down does nothing and I can’t find any keyCodes that does
0x28, // Enter key
0x50, // DPAD Left
0x4F, // DPAD Right
0x52, // DPAD Up
0x51, // DPAD Down
0x3E, // F5 key
0x3F, // F6 key
0x40 // F7 key26 June 2024 at 10:31 am #7499raschaaParticipant26 June 2024 at 11:41 am #7501Mikkel JørgensenParticipantYes I’ve seen that page however there are many takers an what keycodes does what when I look for documentations, and those codes I mention in my post is what I’ve been able to find. So I’m really hoping for someone who has programmed it that can share what hex or decimal value they use.
26 June 2024 at 12:30 pm #750326 June 2024 at 1:02 pm #7504João PereiraKeymasterYou cannot do more than sending those key codes.
For functions it needs to be done by us because we will have different functions according to the number of buttons available.
26 June 2024 at 3:27 pm #7505Mikkel JørgensenParticipantI think you misunderstand me.
I’m not trying to do anything beyond the description on on the “controller-implementation-guide” page. My device is registered as DMD2 CTL 8K and I’m using the keycodes as described in my original post. I found the keycodes here https://usb.org/sites/default/files/hut1_5.pdf on page 91.The problem is that while all the other keycodes work the ones for UP and down doesn’t all the other buttons have work as intended
26 June 2024 at 3:58 pm #7506João PereiraKeymaster[quote quote=7505]I think you misunderstand me. I’m not trying to do anything beyond the description on on the “controller-implementation-guide” page. My device is registered as DMD2 CTL 8K and I’m using the keycodes as described in my original post. I found the keycodes here https://usb.org/sites/default/files/hut1_5.pdf on page 91. The problem is that while all the other keycodes work the ones for UP and down doesn’t all the other buttons have work as intended[/quote]
In DMD2 – Global Settings – Select remote controller model -> Did you select the Generic 8 Key entry?
26 June 2024 at 4:01 pm #7507Mikkel JørgensenParticipantIt doesn’t work at all when I set the controller model, it only does something when i let it auto detect
