  • #1862
    Rainer
    Would be great if you could fix the manual setting of the tilt mode (or even only on= max tilt) for the current direction up map mode – don‘t really see why you would need a tilt for the other two modes of the map, and I personally don‘t see a big advantage of different nap tilts other than off or max.
    #1882
    I think I understood this one, you are saying that manually adjusting the tilt should only be available when the Direction Up mode is enabled. Correct? If so I do agree! Will look into that.
    Rainer
    Yes, and I personally think being able to fintune the tilt is one of those features that make the interface more complicated without really bringing that much of a benefit – so I’d rather keep it simple 😉
