5 May 2023 at 3:58 pm #1700SolTroyParticipant
The Beta already is awesome but what I’d like to be able to….
- Set the amount of pages for the left and right widget in the home screen
I personally don’t need 3 on each side. - Possibility to completely remove the bottom widget to extend the height of the other widgets on home screen
- Option to hide the Poweroff section from the navigation bar
I use Tasker with AutoTool as SystemLauncher to set the actual launcher based on usage of my Phone. I guess if DMDv2 would be the SystemLauncher the button would be automatically hidden, but because AutoTool sits ‘between’ DMDv2 can’t recognize that it’s the default launcher. You could also add a ‘Exit DMDv2’ button to the settings menu if the section is hidden.
And yes – I will add another topic of the tasker setup as soon as it’s working bomb-proof.
Last but no least, thanks for this wonderful piece of software
6 May 2023 at 12:34 pm #1720João PereiraKeymasterThe Beta already is awesome but what I’d like to be able to….
- Set the amount of pages for the left and right widget in the home screen I personally don’t need 3 on each side.
- Option to hide the Poweroff section from the navigation bar I use Tasker with AutoTool as SystemLauncher to set the actual launcher based on usage of my Phone. I guess if DMDv2 would be the SystemLauncher the button would be automatically hidden, but because AutoTool sits ‘between’ DMDv2 can’t recognize that it’s the default launcher. You could also add a ‘Exit DMDv2’ button to the settings menu if the section is hidden. And yes – I will add another topic of the tasker setup as soon as it’s working bomb-proof.
Thank you!!
I totally agree with the first two and will implement. Not exactly sure how to make the third request possible but I will try!
Buy Me a Coffee - Set the amount of pages for the left and right widget in the home screen
