28 May 2024 at 10:45 am #6303
carsten
ParticipantHi.
I‘m really desperate. I‘m on a trip in Finland (mostly TET). Before I left home I updated DMD2 from 3.00067 to 3.00069. When I left my home near Berlin I noticed frequent crashes of DMD2. They disappeared when I got some distance to the town. They came back in Schwerin. Again, a town. It was a pain, but I thought I can handle this. But now I‘m in the middle of nowhere in Finland and the app still crashes sometimes every 100 meters. I updated to 3.00070, but this didn‘t change anything. Please help, I‘m most of the time blind!
Carsten
28 May 2024 at 11:09 am #6304carsten
ParticipantI should add the following:
- I running Android 11
- I‘m navigating tracks created by Kurviger
- I‘m using the Home Screen with Navigation and Progress widgets
Carsten
28 May 2024 at 11:46 am #6305carsten
ParticipantI can add some more things I observed / tried:
- When I immediately stop if DMD2 crashes it restarts and often crashes again and again and so so on. That is, I don‘t have to move. Crashes occurring while I‘m standing.
- I tried to disable all progress warning. This doesn‘t change anything
- I tried to use the Maps screen for navigation. This also doesn‘t help.
Carsten
28 May 2024 at 12:12 pm #6306João Pereira
KeymasterAre you using routing feature?
28 May 2024 at 12:49 pm #6307carsten
ParticipantI don‘t think so. I just loaded the track. I didn‘t convert it to a route. But this is one thing I considered to try. Might this help?
Carsten
28 May 2024 at 1:12 pm #6308carsten
ParticipantOne more information I can add in this context:
I have loaded
- A track for each day of my trip.
- A track with the complete route
- A track with an alternate route
- The TET file
That is, there are overlapping tracks loaded. But only the track for the day is at the moment visible. Might this be a problem?
Carsten
28 May 2024 at 1:54 pm #6309João Pereira
KeymasterCan you send all your loaded files? Send it to info@drivemodedashboard.com and i will load it on my unit to see if i can reproduce.
28 May 2024 at 2:12 pm #6310carsten
ParticipantAs soon as I find a strong WiFi spot I will do it. Anything else I could check / try?
Carsten
28 May 2024 at 6:35 pm #6319carsten
ParticipantI send you an Email with the files. One more detail: Track recording is turned on
Carsten
23 July 2024 at 9:37 am #7820Johann Strasser
ParticipantHello, My CarpeIter also crashes all the time in Bosnia. Some drivers had this Problem.
It was not possible to use DMD2 Roadbook funktion. This Problem startet when i used the km correctionsfactor.
