15 August 2023 at 11:15 am #2843
TheHuskyCrobats
ParticipantGreetings to all,
I have a question regarding the hardware part of a DMD-T665 Nav Phone.
Is the device compatible with Android Auto? I’m not referring to DMD2, but to the hardware unit itself. Can I use Waze on it, for example?
If the USB cable included with the magnetic charger is used, can the device communicate with the motorcycle unit through this cable? I have a motorcycle that supports Android Auto.
Or do I need to use another USB-C cable connected to the DMD-T665 Nav Phone to enable Android Auto?I ask this because I am now using a phone, connected with a USB cable to the motorcycle unit. In this case, with the actual phone, I can have Google Maps or Waze on the motorcycle unit and another application, not supported by Android Auto, on the phone.
I would like to use gpx tracks on one screen and waze on another screen
and I would like to use a robust and dedicated unit for something like the DMD-T665 instead of my phone.
This topic was modified 1 year, 8 months ago by
TheHuskyCrobats.
16 August 2023 at 10:52 am #2850João Pereira
KeymasterHello
The device is compatible with Android Auto but the cradle will only do charging, even if you plug a USB cable to it its only good for charging.
Sorry about that, if it was me I would just add a wireless Android Auto module to the motorcycle, they are so cheap and work flawless.
I personally use https://www.aawireless.io/AAuto
Buy Me a Coffee16 August 2023 at 11:02 am #2851TheHuskyCrobats
ParticipantThank you for your reply.
Now it’s clear to me, if I want to use Android Auto I have to connect a USB cable directly to the USB-C port on the phone.
I have a wireless AA device, just like the one in your link, but I’m still having trouble using it with my bike. However, it works flawlessly in my car.I just put the order for the DMD unit
This reply was modified 1 year, 8 months ago by
TheHuskyCrobats.
