  • #34716
    chico
    Help wanted on DMD2 not recognizing the new Silverfox C1.
    This is a repost from the Controller forum. Posted it here as well, maybe the nice DMD2 software people can help:
    Just installed the new Silverfox C1 controller via the wired option, Bluetooth off.
    The T865X/DMD2 recognizes it as an H1, then the Pan joystick works (although very sluggish).
    The other joystick does not work. When tested in Buttons App, it sees it as 3 buttons instead of a joystick.
    Latest DMD software is installed. Also the reset function to choose controller 1/2 or controller 3 gives no result.
    Is it possible to manually install the C1 ?
    The buttons app cannot be reset ?
    How to reset the whole system, so I can retry?
    The silverfox controllers installed by wire should be Plug and Play, right ?
    Also in a Bluetooth connection it is still recognized as an H1…
