18 May 2023 at 9:45 am #1927
Rainer
ParticipantI understand that it is nice to have certain functions as a short cut reachable directly from the map view – however currently, for example when you navigate a router there is about 50% of the map blocked with buttons and overlays, and some of them could be easily grouped so stream-line and therefor simplify the UI and at the same time have more area for the map.
I think only buttons you really need a lot should be visible, anything else should be grouped e.g. under options.
Often used during navigation are:
– Map orientation
– lock icon,
– POI
– options icon
Everything else should move to the options dialog
IF the zoom in/zoom out buttons would be much more transparent (maybe 80%) in the situation where you do not display the extra info boxes on the right side they would hardy block the map (so increase map size) – after all you do not need to grasp any information of them but only to have an orientation where you need to press.
However, When the extra info boxes on the right are displayed it certrainly looks better the way it is, and there is nothing to be gained by making them more transparent.
It would also allow for more map area if there would be an option to disable the info boxes on the right completely (including the thin show/hide button on the top, which would allow to move the option button more to the right hand side when the info boxes are disabled. (but maybe that’s already there and I did not see it).
In any case: the new satellite view button should be part of the map layer selection, and the layer selection should move to the options maybe at the top of the list or in a special section at the top of the list.-
This topic was modified 1 year, 11 months ago by
Rainer.
30 April 2024 at 4:54 am #5153Richard Kmiec
ParticipantI agree, has there been any response on this? On my older dmd2 version I was able to customize/hide more buttons, but on this latest version I cannot find that option
30 April 2024 at 10:05 pm #5221João Pereira
KeymasterThe buttons you need or not are different from user to user.
We can add option to select what to be visible or not. Most of the layout is originally for tablets where there is plenty of room for everything.
Let me think about how to make this user configurable. For me personally I use most of the buttons and when I ride I like everything accessible with the minimal amount of taps.
Another I will probably add is ability to hide elements when moving. For example, as soon as you start moving hide bottom bar (a bit like the auto lock when moving).
Buy Me a Coffee30 April 2024 at 11:02 pm #5231Richard Kmiec
ParticipantThanks for looking into this, I think a bunch of us still just use phones so screen space is at a premium. I remember the older DMD2 that I used had options to have some buttons visible or not, at least that’s what I remember. Or maybe if we just have an option to make the buttons smaller would help as well
This reply was modified 11 months, 3 weeks ago by
Richard Kmiec.
