I did search in the forum for this, but could not find anything so I wanted to ask this. I do not quite remember on which version of the DMD, but at some point the DMD theme was set only on dark and light and we lost the selection SENSOR or THEME (I do not remember exactly how it was named)? I assume this was done for a reason, but is it something that you are planning to bring back in the future? If not, could you please consider simply adding a timer/clock to change between LIGHT and DARK that we can set? I find it really useful to have the LIGHT theme during sunny days, as it makes reading much easier, but I also enjoy the comfort of the DARK theme while traveling at night.
Thank you!
Sorry but this will take a while to be brought back since it was causing some issues.
I will not highjack this threat, but I would like to add some more details:
1. In main config, it’s selectable, which colour schema would be preferred – but possibility is olny dark or light.
This changes only color schema of application itself (menues, icons, etc.).
Missing is the option, to use automatically given device settings (my along sun rising)
2. in config menue about map type and style, there are 3 options (dark, light, and thema of device settings). Vice versa to main config, here we have all needed 3 options.
But the option “device thema” isn’t working; it ignores the settings in device – map in DMD App stays always dark!
