Don’t know if the problem is really in DMD2 ou perhaps in the Buttons app ?
When I’m on the map view, everything works fine with the Silverfox H1 : zoom in, zoom out, map panning, screen blocking, recentering of the map on my location …
I do a long press on the “enter” button (top one), it opens the menu arrows, I go to the home view and return to the map view with the joystick and do a validation with a press on the “enter” button.
And at this time, the only button which does something is the “enter” one which open the first application on the top of my applications view ; and I saw that by moving the joystick to the right, the “enter” button opened the 2° application of my applications view (allways on the map view) ; as if the controller thought it was on the applications view while one is on the map view.
Then I exit the application opened and the controller works fine again on the map view ! Note, if I do only a roundtrip between map view and application view and return, there is no problem.
Otherwise the controller works fine in every view/application.
Configuration : Android 12, DMD2 3.00149, Buttons 1.34, DMD controller parameter set to “Silverfox H1” and I changed the menu bar as follows : map, applications, home, settings and output (in the order from left to right).
I have the exact same issue, but I dont know whats triggering it.
I couldnt find out whats causing it, but if it happens, I cant scroll or zoom on the map view anymore.
When I check if the inputs are working (in the Buttons App) all buttons and the D-Pad are working fine.
I use the DMD Remote 2 on Android 14 and DMD 3.00148.
Before the Android 14 Update I never had that issue.
