  • #33474
    Neelbilly
    Is it possible to change the color of each of your tracks? When I try to change the color of an individual track, it changes them all to the color that I’ve chosen.
    #33477
    Yes you can individually set the color of each track. Just tested it in my device and it works perfectly.
    To do this you tap the round GPX button in the map view, tap on the GPX file name that contains the tracks, then tap on the “TRACKS” button on the right, there you can set the color for each of the tracks.
    Neelbilly
    That worked! I was tapping the track, but I wasn’t tapping the button beside it called “track 1”
    Thank you!
