In the configuration menu for the bottom buttons, the Exit and Global Settings icons do not have a Toggle Switch to show or hide them. Is this normal, or a bug?
The Global Settings icon, tho it doesn’t have a show/hide toggle switch, IS present in the bottom bar. I’d like to add the Exit icon to the bottom “on screen” menu, but can’t.
I’ve tried moving/putting the icons in a different order to see if that will enable a toggle switch for the Exit icon. It’ doesn’t.
Thanks for any info.
If you go to Global Settings and hide the Global Setting from the bottom menu how would you go back to Global Settings (it would never be available again).
Shutdown button depends if the app is set as you home launcher or not, because if the app is the home launcher you cannot close it (its the phone root level).
This is explained here: https://www.drivemodedashboard.com/getting-started/
Thanks for the explanation. The first time I watched those videos after getting my device, a lot of that information went over my head. Now after a few weeks of getting to know my way around DMD and the tablets OS, I’m getting an idea where things are and how/why they work the way they do and the interactions between them.
Tho I still come across a few things now and then that don’t make sense initially. I still sometimes get DMD and the tablet OS functions mixed up.
