Viewing 9 posts - 1 through 9 (of 9 total)
  • #657
    CARLO VILLOIS
    Hi, I would like to design my pushbuttons controller to be mounted on the handlebar using an Adafruit Feather 32u4 Bluetooth programmable card but, in order to send  the correct commands to the DMD2 application I would need the list of available commands (Arduino IDE format). For other App I can send via Bluetooth the command from my pushbuttons controller as KEYBOARD COMMAND. For exanple for LOCUS MAPS I have the following commands:
    ZOOM IN = VOLUME +
    ZOOM OUT = VOLUME –
    MAP UP = r (00-00-15-00-00-00-00)
    CENTER MAP = c (00-00-06-00-00-00-00)
    DISPLAY ON/OFF = d (00-00-07-00-00-00-00)
    Thank you in advance for your help.
    Best regards
    • This topic was modified 2 years, 3 months ago by João Pereira. Reason: Moved to correct forum
    CARLO VILLOIS
    #658
    remapping bluethootcontroller
    #666
    Although a lot of people do not know this, DMD2 is not a profitable app.
    Which is fine for us, we never looked at it as a finished, commercially ready product.
    BUT, it will soon be, on the next big update with new UI and many new things.
    What allows us to keep investing on this app is deals with OEMs, like AJP, Fantic, CARPE.
    Specially CARPE because we sell the controllers and the profit from the sales allows us to keep our business running and having developers 8h / day working on DMD2.
    For this reason DMD2 will not allow you to use any other controller unless it is a CARPE controller.
    Maybe in the future when DMD2 matures and becomes a sustainable app we can allow and support other controllers.
    CARLO VILLOIS
    Good afternoon John,
    thank you very much for your reply.
    CARLO VILLOIS
    #854
    spencer.chedid
    Hi there,
    I got the same BT controller though I doesn’t seem to work with DMD2. Is there any additional configuration?
    FYI I managed to get it setup just fine for Locus Maps and it works.
    TIA.
    #857
    Hi there, I got the same BT controller though I doesn’t seem to work with DMD2. Is there any additional configuration? FYI I managed to get it setup just fine for Locus Maps and it works. TIA.
    No that controller will not work, only CARPE controllers work with DMD2.
    spencer.chedid
    Thank you for clarifying.
    #2680
    jipppo13
    I have to Silver Fox Controller from Finland. It seems to work fine, but am not sure on all the button functions. I have downloaded the firmware that was associated with DMD2. It would be nice to have some sort of user guide (if possible).
    Here are some of the button function based on the Silver Fox website (URL: https://www.silverfoxcontrollers.com/apps1)
    Here are the basic functions in map view:
    Joystick: Panorating Up – Down – Left – Right
    Plus and Minus buttons: Zoom in  – out
    Center button: Center the map and toggle between orientaton views
    Hold center: activates the page selector for other views (home/map/roadbook/OBDview ..)
    • This reply was modified 1 year, 5 months ago by jipppo13.
    #4005
    avazquez
    With ANNALORO80GMAIL-COM controller i use keymapper app and it works great . You can use the Road book map, OsmAnd and anything you figure out sincenyou can Mapp any key or combination .
    ANNALORO80GMAIL-COM how do you fix the controller ?
