24 February 2024 at 10:20 pm #3973
Severian
ParticipantYes… one more thing: “back to track” vector is super useful in real life, indeed!
27 February 2024 at 9:37 am #3978Paraendurist
ParticipantHello John
When we use Speed on the main Screen it means we use gps speed. Because it is GPS Speed we will loose the GPS signal in tunnels. Would it be possible to replace GPS Speed in the Main view with odo speed as soon as the gps signal is lost??This would make the use of the Main Speed much more reliable.
27 February 2024 at 10:58 am #3979sveni
ParticipantWhy is it that I can’t see any higher version in play store than 3.00032
//Sven
This reply was modified 1 year, 1 month ago by
sveni.
27 February 2024 at 11:09 am #3981Brutus
ParticipantGoogle is arguing about something, more info about it on DMD2 FB…
we just have to wait, DMD team is working on a solution
27 February 2024 at 2:52 pm #3982Severian
ParticipantSeems to me that obvious path to choose is to avoid Google Play for all devices. This will probably raise questions about easy licensing, but I think it will worth it… No point to keep Google as a show stopper… with the hefty fee, too.
28 February 2024 at 12:10 pm #3983Severian
Participant3.00039 (??) available on play store… We’ll see change log (hopefully), but probably it’s bye, bye foreground service…
29 February 2024 at 10:38 pm #3988navnerd
ParticipantToday I installed 3.00039 on my device: The foreground service message on exit is really gone :-(. When switching to the device home screen (and not exiting DMD2!), the trip is not incremented and straight lines are drawn…
. Also, switching the screen off during DMD trip recording leads to the same problem.
So, that forces us to use DMD2 as start app and NEVER use another app over it that may switch the screen off (like during a phone call…). The only workaround currently is to record the trip with a third party app (like GPX logger recommended by Severian – it works really great! :-)).
John, can’t you explain the Google reviewer / approver that this will cost Google license fees (American companies are usually very sensitive to this…)? This is a huge limitation of functionality of a navigation / trip logging app!! Google has allowed the wished behavior already in DMD1 (which I sometimes still use :-). Why don’t they allow it in DMD2? –> Explain and ask him. May be the forum participants should send him a protest petition…
Probably the best solution really is providing an apk-download outside the google play store, if that discussion still does not help…
1 March 2024 at 11:40 am #3989fasteddy
ParticipantGood Morning, has there been any thought on porting DMD2 app to work on ChromeOS tablets? I’m not a developer but I do see quite a few Android apps running on that platform.
Thanks
fasteddy.
1 March 2024 at 4:37 pm #3998Bruno de Sere
ParticipantHello
For the Garmin Tread platform that will be a nice feature to have in the setting the possibility to store the maps on the external SD drive. It will be pretty cool when you activate this feature to copy all existing maps to the SD cards and if you desactivate it to recopy the maps from the SD card to the internal storage (data partition).
Best regards
8 March 2024 at 11:55 am #4104Severian
ParticipantVer 3.00041 crashing on start, after update from 39. Android 14, Oneplus phone.
Bug update: seems to me that crashes occurs when there is no gps fix. When phone has gps location locked, ver 41 sometimes starts fine and sometimes still crashes.
