2 January 2024 at 1:27 am #3732
klaasbloem
ParticipantWish I could adjust the size of the four Android shortcuts on the home screen, they look too big on my Galaxy Note 8 IMHO.
12 January 2024 at 11:26 am #3779João Pereira
KeymasterVer 3.00020, Home view: When set in top left corner of the gps/obd widget, ODO value can not be reseted/edited with long press. Works fine with ODO in other locations.
Fixed for next update
Buy Me a Coffee12 January 2024 at 4:10 pm #3781João Pereira
KeymasterDMD2 – 3.00022:
– Fixed a case where Odo view would not trigger dialog on long press when loaded in first slot of the GPS/OBD widget
– Large GPX files import improvements
– GPX direction reversion for Routes
– Other improvements and optimisationsDMD2 – 3.00021:
– DMD2 now responds to SOS messages from new (soon to be released) DMD-T devices SOS system
– DMD2 recorder / trip / etc now works with screen off -> only for DMD-T devices – other devices pending Background Location permission at Google Play Store
– Optimised POI search/database – Might require pending map updates on some countries
– Minor UI improvements
– Fixed a case where first run – default configurations for map related settings (track width, track arrow, scaling, etc) was not being applied on phone type devices
– Updated translations
– Other minor fixes and improvementsDMD2 Project Manager & Lead Developer
Buy Me a Coffee12 January 2024 at 5:15 pm #3782Severian
ParticipantDMD2 recorder / trip / etc now works with screen off
Very nice! Hallelujah!
12 January 2024 at 8:41 pm #3784navnerd
ParticipantGreat news regarding background operation; thanks John!
Just found out that 3.00022 still does not allow the setting to access location in the background. When does Google play store allow background location access? Is that a formal approval process there? No idea about it. Let us know…
15 January 2024 at 2:59 pm #3788jesper
ParticipantHi John
Nice to see you added support for 4 button controller!
Could you make the title bar of the widgets autohide? So that it only shows when changing between widget pages. Then we get more space for the widget itself. Especially for the map widget.Also, any updates on OBD speed for the center widget?
BR
Jesper
15 January 2024 at 6:31 pm #3790João Pereira
KeymasterDMD2 – 3.00023:
– Route Calculation can now do matches to closest available road in case point is too far from roads
– Route Re-Calculation now increases matching ranges automatically
– Improved the recalculation feature for both single destination and GPX to Calculated Route conversion
– Calculation speed should be improved
– Fixed a case where on previous version when GPX to Route conversion failed instead of error dialog it would calculate to last valid destinationDMD2 Project Manager & Lead Developer
Buy Me a Coffee16 January 2024 at 2:28 pm #3804João Pereira
KeymasterDMD2 – 3.00024:
– GPX Progress Window: You can now click on Auto POI icons to view more info
– Greatly increased GPX Load speed
– Greatly increased GPX Auto-POI speedDMD2 Project Manager & Lead Developer
Buy Me a Coffee21 January 2024 at 8:15 am #3813Paraendurist
ParticipantHello Joao .Its getting better and better. But in 26 there is a little bug in landscape the bottom menue disappears sometimes on start , when you calculate a route or other actions. When you then lock and unlock the screen it reappears. Funny
23 January 2024 at 3:48 pm #3816João Pereira
KeymasterHello Joao .Its getting better and better. But in 26 there is a little bug in landscape the bottom menue disappears sometimes on start , when you calculate a route or other actions. When you then lock and unlock the screen it reappears. Funny
Actually its probably because when you tap the top status bar you can toggle bottom menu visibility
Give it a try!
DMD2 – 3.00027 / 28:
– Improved Goole Maps URL sharing with reverse Geocode
– Map view now shows current road name – you can disable in map settings
– DMD2 can now be closed by BUTTONS app -> future DMD-T devices FW update
– DMD2 will now check for background location permission on DMD-T devices
– Other small improvementsDMD2 – 3.00025/6:
– Fixed a crash where GPX Track segments without points would cause app issues (although these should never exists they are a thing)
– Fixed a case of app crash when user inserts numbers in settings which are text only, now properly validates
– Added support for opening Google Maps URL typesDMD2 Project Manager & Lead Developer
Buy Me a Coffee -
