21 December 2023 at 6:41 pm #3666João PereiraKeymaster
I have a T665. In the current version of DriveMode 3.00007, and the previous one, the screen lock does not work. I press the lock icon, it activates, but I can still move the map if I move my hand or finger, and the rest of the buttons work too.
To everyone talking about the lock feature.
You guys noticed that in the map view settings > go to map view (click the cog wheel in the top right corner) there is a setting to set the behaviour of the lock button right?
Setting: DISABLE MAP TOUCH WHEN LOCKED -> This needs to be enabled for the lock to disable touch
AUTO LOCK WHEN MOVING and AUTO UNLOCK WHEN STOPPED -> Make sure these settings are not messing with your lock functionDMD2 Project Manager & Lead Developer
Buy Me a Coffee21 December 2023 at 6:43 pm #3667João PereiraKeymasterThe setting was enabled, so I just rechecked, now with this last version (3.00016) I can see it again in top middle box, home view. It’s ok. BTW, very nice add-on with different location modes!! Zoom to active track and zoom to active GPX are super useful indeed. Good work! PS: please, invest time in keeping the changelog, if possible. It’s better when one knows what to test 🙂
Ahhh yes about the change log… im a bit lost here, this thread is DMD Beta Progress… but now we are out of the Beta and in Production.
I have not placed change log because the changes are now small stuff in production version (not Beta anymore).
Should i create a new thread for DMD2 Production? Or do i rename this Thread for “DMD2 Development” and we keep using this one?
What do you guys think?
Buy Me a Coffee21 December 2023 at 6:49 pm #3668João PereiraKeymasterAlso guys… for quick stuff please use the discord channel!!!! -> https://discord.com/invite/EXANMZ4Q
Buy Me a Coffee21 December 2023 at 7:15 pm #3669SeverianParticipantShould i create a new thread for DMD2 Production? Or do i rename this Thread for “DMD2 Development” and we keep using this one?
In my opinion, it is better to have everything in one topic, so renaming is more consistent.
Because switch of the color profile restarts the whole app.
And, frankly, this IS the problem. Everyone using light sensor theme switching have this situation regularly: enter the tunnel – app restarts (so, gpx reloads, screen unlocks…), exit the tunnel – app restarts. Then another tunnel, everything again. Very annoying, believe me. Not crucial, true. But annoying, even more true! 🙂
- This reply was modified 1 year, 1 month ago by Severian.
21 December 2023 at 7:44 pm #3671AlkermesParticipantI have a T665. In the current version of DriveMode 3.00007, and the previous one, the screen lock does not work. I press the lock icon, it activates, but I can still move the map if I move my hand or finger, and the rest of the buttons work too.
To everyone talking about the lock feature. You guys noticed that in the map view settings > go to map view (click the cog wheel in the top right corner) there is a setting to set the behaviour of the lock button right? Setting: DISABLE MAP TOUCH WHEN LOCKED -> This needs to be enabled for the lock to disable touch AUTO LOCK WHEN MOVING and AUTO UNLOCK WHEN STOPPED -> Make sure these settings are not messing with your lock function
Solved. Thanks 😉
22 December 2023 at 11:54 am #3680João PereiraKeymasterShould i create a new thread for DMD2 Production? Or do i rename this Thread for “DMD2 Development” and we keep using this one?
Yeah unfortunately that is not a DMD2 issue, thats just how Android applies app themes, it restarts the whole thing.
The only solution for this is if i make my own Theme manager (which is A LOT OF WORK) but something i think i will do sooner or later.Events that restart the app: Theme switch – Rotation switch (if not locked) -> both a living nightmare for apps like DMD2
Buy Me a Coffee22 December 2023 at 12:02 pm #3681João PereiraKeymasterThread title updated.
Last release change logs:
DMD v3.00016:
Map View: New Follow Location Modes (configurable in map view settings)
Cache reset on theme color change
Fixed a bug with lock not working on home view
GPX Progress now shows ETA instead of Travel Time
Other small improvementsDMD v3.00015 released:
Map View: Search – Search by name moved to squares, bottom button replaced with new INSERT COORDINATES function
Map View: Topo Themes – improved barrier type icons
Map View: Settings – new settings to hide widget title labels (to increase value text)
Map View: When locked the widgets will use the full available height (including the space for the hide/show widgets)
Map View: Portrait Layout ONLY – Auto POIs now reduced to displaying only 2 – to increase sizes for texts, was too small
Controllers: Remote1 2-Way Switch Zoom is now inverted (its more intuitive)
All: Top Status Bar: Tap on it hides/shows bottom menu
Many UI improvementsDMD2 v3.00014:
Home View: Added button to lock touch / hide bottom menu
Home View: Controller button B or B long press will trigger lock
Map View: Map Topo Theme – Reduced width of Tracks & Paths
Map View: Fixed a bug with OpenGL rendering map wrong on some Android 14 devices
Made some changes for the app defaults when running for the first time on a phoneDMD2 v3.00013:
Changed some app defaults for the first run
Home View: New widget option for the bottom widget: “EMPTY” which hides bottom section and enlarges remaining space
Fixed a bug with some routing voice instructions for some languages
Fixed a case of incorrect date formats
Bottom Menu in focus mode (controller) now correctly uses the selected accent color
Other bug fixesDMD2 Project Manager & Lead Developer
Buy Me a Coffee22 December 2023 at 7:11 pm #3685SeverianParticipantQuick workaround proposal : to base light/dark theme on sunrise/sunset data instead on the light sensor? Or in addition to the light sensor, as another option.
Not good for tunnels, but good enough for everything else! Including annoying app reset in tunnels (it will just stay in light theme, no big deal. But still at night it will go to dark one).
23 December 2023 at 12:26 pm #3686JörgParticipantI am old and forgetful. That’s why I really liked the automatic start of a new route recording every day.
I have already forgotten several times.A configuration for an automatic start would be very nice.
Otherwise, I updated my Carpe Iter Pad to Android 11 yesterday.
The upgrade went almost without a hitch.- This reply was modified 1 year ago by Jörg.
26 December 2023 at 4:08 pm #3692João PereiraKeymasterI am old and forgetful. That’s why I really liked the automatic start of a new route recording every day. I have already forgotten several times. A configuration for an automatic start would be very nice. Otherwise, I updated my Carpe Iter Pad to Android 11 yesterday. The upgrade went almost without a hitch.
Ah yes this is FOR SURE returning soon.
Quick workaround proposal : to base light/dark theme on sunrise/sunset data instead on the light sensor? Or in addition to the light sensor, as another option. Not good for tunnels, but good enough for everything else! Including annoying app reset in tunnels (it will just stay in light theme, no big deal. But still at night it will go to dark one).
I do not think that solves the issue, because when i enter a dark place like a tunned i do want the app to do dark and when i exit i do want it to go light.
The issue is the reload of the whole app. So the way i see this we will have to stop using the Android theme system (which sucks like every other Android API) and create our own where we reload UI components with new theme without a full app reload.
This is going to be A LOT OF WORK!!! But i think it needs to be done.DMD v3.00017:
App load time improvements
Map load speed improved
Fixed a case of “No Fix” on some devices when rotation lock is set
Fixed case where some widgets would not show the “+” when loaded in center top home position
Minor topo map improvements with zoom level for “barrier” type icons
Other small improvements (as always)DMD2 Project Manager & Lead Developer
Buy Me a Coffee -
