10 November 2023 at 6:11 pm #3343
klaasbloem
ParticipantTop bar looks fine on my 6,3″ screen, bottom is too big for my taste.
10 November 2023 at 8:26 pm #3345Paraendurist
ParticipantHello John
There seems to be a bug in the Map Downloader. Today there have been a lot of map updates. When clocking on update it runs until the end but the update sign remains. When you delete them and load it again it loads correctly10 November 2023 at 9:04 pm #3346klaasbloem
ParticipantHi John,
In portrait mode found 2 problems with loading a widget: The list of system widgeds is shown as a small strip and I can’t load a widget. Hope this helps and glad you are starting to support portrait mode!
Edit: Make that some widgets won’t load, I use the Dutch “buienalarm” (rain alarm) in DMD2 but can’t load it in the Beta.
This reply was modified 1 year, 5 months ago by
klaasbloem.
11 November 2023 at 9:53 am #3348Severian
Same on my 6.59″ screen.
Really like @mp_ ‘s proposal regarding progress box/widgets switch on the top and one button to open all side icons (!)…
14 November 2023 at 4:17 pm #3355mp_
Same on my 6.59″ screen. Really like @mp_ ‘s proposal regarding progress box/widgets switch on the top and one button to open all side icons (!)…what do mean, looks fine? doesn’t look huge (6.43″ mine), especially comparing with landscape mode icons have twice the size?
GPX settings modal: I would prefer the Reset button to be red and have a confirmation dialog, it’s easy to click it by mistake, actually it would be great if all “reset/delete” buttons have a confirmation dialog.
v.2.99970
I saw that you “disable” the buttons on GPX Recorder modal but I can still press them, is this intentionally?
15 November 2023 at 12:27 am #3356Severian
Participantv.2.99970
After some time (100km track, issue present after ca. 80km) track progress info box stops working and scaling is messed up:
Disabling track progress info box in map settings does not help (still visible on screen even if disabled). After that, deleting gpx file with track from map does not work either (delete/close/still visible in map view).
After reseting, everything works again.
16 November 2023 at 10:33 am #3361João Pereira
Keymasterv.2.99970 After some time (100km track, issue present after ca. 80km) track progress info box stops working and scaling is messed up:
Disabling track progress info box in map settings does not help (still visible on screen even if disabled). After that, deleting gpx file with track from map does not work either (delete/close/still visible in map view). After reseting, everything works again.
Can you send me a copy of this GPX file so I can do a simulation, you can send to info@drivemodedashboard.com
Thank youDMD2 Project Manager & Lead Developer
Buy Me a Coffee16 November 2023 at 10:49 am #3362Severian
ParticipantSent.
16 November 2023 at 2:26 pm #3365Paraendurist
Its getting better and better. As you promissed the first loding of gpx files is now super fast. But its not wenn you have tp reload or when the poi feature is ticked . When poi is ticked its slower than before and there is no indication whats going on17 November 2023 at 5:47 am #3368Paraendurist
ParticipantHello Joao
Woulf it be possible to offer obd speed on main screen as big indicator ad a choice because when in tunnels gps is dead. And 2hen in use as main control its more usefull -
