Viewing 10 posts - 711 through 720 (of 943 total)
  • #3087
    Paraendurist
    Hello John looks good 57 but when I scroll in the map with loaded tracks it allways reloads the tracks dont know why
    #3114
    Beta 2.99958 released:
    – Greatly increased memory efficiency with GPX files handling
    – Added WonderLINQ controller full support – (Requires WonderLINQ firmware 2.2 and set to DMD2)
    – Added Android 13 Post Notification permission request
    Ralphs
    USB-C charging issues Carpe Iter. I updated from version 49 to 57 and the device doesn’t charge anymore. it ran down to zero on a charger and now it keeps restarting all the time. Anybody with the same problem? Could be obviously unrelated to the software upgrade
    #3118
    fratha
    Hello John
    I have same problems If a calculated a gpx File to a turn by Turn navigation.
    If i Use fast IT always calculated Not to end of the track
    See Pictures
    #3123
    fratha
    New bug in dmd2 Beta
    if you set the rerouting Option below 150 m
    you can Route Bit you dont see the routing popup
    #3124
    Jörg
    I tried today to open the gpx file (track) recorded by DMD2 with Garmin Base Camp. An error message came up.
    I do not necessarily need it, but should it not work?
    But maybe it is also because of the Garmin software.
    #3126
    Severian
    No, it is not. Tracks recorded with production version can be opened with Basecamp just fine.
    #3141
    Jimmid
    Apparently Google is stopping the saving of offline maps to SD card in beta.  It worked ok in the version before I changed to beta and I have the maps on my SD card.  Is there a way I can tell the program to use the maps on my SD card?
    #3142
    fratha
    Hello John,
    DMD2 Beta .59
    When a route is recalculated, the voice prompt will be updated
    but the routing path is not updated …
    #3146
    fratha
    Hello John,
    Bug in dmd2 beta .60
    gpx manger – track loaded – select track option – convert to route dmd2 beta crash on tripltek 9 pro …
