25 August 2023 at 7:07 pm #2983ParaenduristParticipant
This sounds really great John
26 August 2023 at 7:40 pm #2986ParaenduristParticipant<p style=”text-align: left;”>Hello John</p>
I could not find out how to reset fuel by long press outside the obd page. I have the fuel un map left side and on main page in the obd widget in the middle both do not react but show the edit pageWhat I am doing wrong?
26 August 2023 at 8:35 pm #2987JörgParticipanthi John,
i love the new power indicator on the top left.
Could you make the font color according to the direction, green when charging, red when discharging.
Greetings Joerg
27 August 2023 at 2:21 am #2988MonteParticipanthi John, i love the new power indicator on the top left. Could you make the font color according to the direction, green when charging, red when discharging. Greetings Joerg
100% THIS !!
27 August 2023 at 7:39 am #2989SeverianParticipanthi John, i love the new power indicator on the top left. Could you make the font color according to the direction, green when charging, red when discharging.
VERY good suggestion, 100% useful!
28 August 2023 at 3:34 pm #2990JörgParticipantHi John,
I think there is a strange bug with the sign on the mA display.
On my Ci-Pad, a minus value is displayed without charge.
With voltage supply, no minus is displayed. Everything is ok.
On my Xiaomi phone mi9 it is the other way round. Minus is displayed when charging.
On a Samsung S10+, only -1 to 0 mA is displayed.
But the path is correct.28 August 2023 at 6:20 pm #2991Ejj75ParticipantSamsung Galaxy Active 3
Version 2.99949. Absolutely really nice features has launched.
Auto lock when moving: UI lock works
Auto unlock when stopped: UI does not unlock when stop moving (after 5 min still locked). The UI lock cannot be opened on the home screen and app can not close (unlock and app close buttons are missing due to UI lock).
Current now:
Not in charger: Value is -1 mA…0mA (Should be -500…-800mA).
Fast charger connected: Value is first 2mA (should be 1500-2000mA) and then decreases to 0…1mA.
Motorcycle charger: Value is first 1mA and decreasess to 0mA after few seconds (real value should be 400-600mA).
Could the indication values be amps instead of milliamps?
29 August 2023 at 5:18 pm #2994João PereiraKeymasterSamsung Galaxy Active 3 Version 2.99949. Absolutely really nice features has launched. Auto lock when moving: UI lock works Auto unlock when stopped: UI does not unlock when stop moving (after 5 min still locked). The UI lock cannot be opened on the home screen and app can not close (unlock and app close buttons are missing due to UI lock). Current now: Not in charger: Value is -1 mA…0mA (Should be -500…-800mA). Fast charger connected: Value is first 2mA (should be 1500-2000mA) and then decreases to 0…1mA. Motorcycle charger: Value is first 1mA and decreasess to 0mA after few seconds (real value should be 400-600mA). Could the indication values be amps instead of milliamps?
Sorry but not all devices allow for Current Now report. Im absolutely sure my code is the correct code, works perfect on all my devices too, if any device is showing wrong values I can assure you that the manufacturer changed stuff that they should have not changed (usually the case with Samsung).
Beta 2.99950:
– When map is locked (with the touch screen lock settings enabled) other UI elements are hidden too
– Address Search – Will now show history for the last 10 items that you searched and actually clicked for either Navigate or Share
– Map Lock Button – To unlock it now requires long press
– Fixed a bug with Clock Widgets where non 24h mode was not being respected
– Fixed a crash on map widgets long press where it would cause crash when there was no widget loaded
– Auto Map Lock settings (map view settings) now, correctly, wont lock screen when you are not in the map view or in the map view settings screenDMD2 Project Manager & Lead Developer
Buy Me a Coffee29 August 2023 at 5:21 pm #2995João PereiraKeymaster<p style=”text-align: left;”>Hello John</p> I could not find out how to reset fuel by long press outside the obd page. I have the fuel un map left side and on main page in the obd widget in the middle both do not react but show the edit page What I am doing wrong?
Long press on the fuel indicator in the map widgets area will indeed show the dialog. The dialog first button is “RESET”.
Change font color according to CHARGING state or according to CURRENT NOW being positive or negative?
Buy Me a Coffee29 August 2023 at 5:27 pm #2996 -
