Viewing 10 posts - 641 through 650 (of 943 total)
  • #1549
    Abyss79
    Hello John Im testing every day the trip Home - Work and Work - home and today the recalculation was ok, I didnt get any crash. I know that you are more off road oriented, but also on the everyday ride on paved road, so using it on the easy Sunday ride will be great to have a screen with both map and direction information and other OBS/trip information. In the Home screen the map view on the left is perfect, but you miss the turn-by-turn notification, so will be great to have. – A widget on the right side to list all the next direction instruction with the next waypoint or activated POI, I guess we can have a list of 4/5 elements with Name Km left and time – When you are close to a direction change, according to speed 100m before or more if you are going fast on that new widget and maybe also on the trip widget should become a big signal with the indication and the distance left, like when you are in MAP view and you have the small icon tell YOU TURN RIGHT NOW Example Christian
    Holly crap man, you actually wasted time doing that to explain it to me???!!! I mean thank you a lot, thats a lot of dedication… but in all honesty, you actually think such feature would not be available? Thats planned almost since the first mock we did 😛 The information you have on the left side box in the map view will OBVIOUSLY be also available as a widget 😛 Now, here is what im thinking, currently we have two left side boxes: – Track Progress – when you are on a GPX track – Nav Progress – when you are navigating a planned route My idea is to make a widget like “Nav & GPX Info” which, when you are on the GPX Track will show you the gpx progress information (with distances to next waypoints or POIs) and when you are on a planned route it will show you the Nav Progress info. So its one widget that covers two scenarios. This is all easy and fun, the real problem will come later, when you have stuff like “instructions for gpx tracks” so now on the left side of the screen I need to find room for the current information PLUS instructions. Same for when I add support for GPX ROUTES which although are GPX Files and should be managed in the GPX Manager they get converted to calculated routes so they have instructions too… not only I need to find solutions for the info but also adapt the gpx manager layout and code to deal with GPX Routes…. its a nightmare!
    🙂 Good to know! I was born as developper..so I like this kind of stuff…. And I like this project. because I realy use it!!
    It`s a very usefull APP and it will become even more…usefull
    Thanks
    #1559
    laode_ontahood
    Hi John,
    I’m using iter carpe v4. Just received few days ago. I already join beta tester. But, why on my home section,  I couldn’t put map widget? How to do it?
    #1560
    laode_ontahood
    Hi John,
    #1748
    klaasbloem
    You could use a app called “fake gps location” while in your room: https://play.google.com/store/apps/details?id=com.lexa.fakegps&hl=en_US
    #2037
    jesper
    A device with Play Store required you to buy the license from the Play Store… this is mandatory or Google will quickly ban us from Play Store. The standalone license (which you buy from the Thork Racing website) can really only be used with devices without Google Play Store. Sorry about that!
    No problem, such is life. I will start with the Play Store version then. And then buy the standalone when I switch device. What about OBD Speed and the number of button presses to switch between widgets? Best regards Jesper
    Will fix that soon.
    Awesome! 😀
    #2223
    harupipapa
    Certainly there is a setting for continuous key presses in the load book settings, F5 (button 1 of bar buttons) is valid. but This function is disabled for” F6″ and” F7″ (button 1 and button 2 of bar buttons). Upon inspection, the DMD Roadbook’s corresponds to button A “Keycode EQUALS” &” keycode A” is valid “F6 “is disabled corresponds to button B “keycode minus” &” keycode escape “&”keycode C” &” keycode Back” enabled “F7” is disabled Please check and fix.
    You making it all confusing, there should be a specific firmware for that controller provided by the manufacturer. I have no idea why you are talking about key code C or key code minus, or key code escape… I will check it after tomorrow with the controller provided by the manufacturer with its firmware. DMD2 is not just about KeyCodes… its about correct key events and making sure DMD2 recognises the controller model.
    Sorry for making things difficult.
    I understand it works with some code to keep controllers compatible. (There are other conditions as well)
    To understand if this issue is caused by controller side or DMD2 side.
    I wanted to tell you that it works fine with other keycodes.
    #2224
    harupipapa
    #2261
    Monte
    Hi John, Running the DMD2 Beta and just installed the Carpe ADV controller. Generally loving it, and definitely loving DMD2. I do have one question/issue? When I use the joystick to pan in map mode I have no idea how to return to regular mode (i.e. regular view centered on my location) In ‘regular’ map centered view I can use the top button (Enter) to toggle from Follow Me to North UP, etc. However once I enter pan mode, the enter key instantly brings up the ‘Long Press on Map’ dialog and there is no way to get back to regular map mode. I’m guessing there is a key press sequence to get out of panning mode but I can’t seem to figure it out. Thanks
    I have exactly the same problem but it may be user error that I do not know how to get around it or it could be an issue with the Adventure Controller
    Would love to know the answer to that as well
    After you enter the “panning mode” to disable just long press the last button in the controller (bottom button), long press the minus button is always “BACK or EXIT” You can disable panning mode in the Map Settings (cog wheel in the top right corner in the map), just click on “Disable Panning Mode Target”
    Thanks John. Really appreciate all your work. App is amazing and getting better by the day.
    #2397
    voorstad
    Does this issue belong in this topic perhaps?
    #2398
    voorstad
