5 June 2023 at 9:06 pm #2198mp_Participant
Beta 2.99919. Is there a method of entering a street address and/or lat-long co-ords directly into the DMD2 map screen ?? I can manual move & zoom the map with my fingers to find the location, and then select “Navigate”, but there does not seem to be a method of just typing the information into the map ??
Nop, not yet.
5 June 2023 at 10:03 pm #2199klaasbloemParticipantHi It looks like DMD2 is using a lot of power even when the screen us turned off/locked. Is it possible to make the app pause GPS when the screen is locked? Or maybe have an option where it goes to sleep when charging stops? BR Jesper
That happened to me on the non beta version with a active compass rose on the home screen, I guess DMD2 was constantly searching for a GPS fix (and not finding it inside my home).
6 June 2023 at 9:10 am #2200harupipapaParticipantapparently
The keycode F5 seems to support continuous presses.
The keycodes F6 and F7 don’t seem to support continuous presses.in roadbook mode
When working with a PDF, pressing the button scrolls only once.
You have to press the button each time.
It’s a pain to press the button every time you want to look ahead in the PDF.
Is this the specification?
I want continuous operation just by pressing a buttoncan you fix it?
bar button
galaxy tab active3
latest beta- This reply was modified 1 year, 6 months ago by harupipapa.
7 June 2023 at 10:41 am #2206klaasbloemParticipantHi John, any plans for a portrait mode in the beta version?
7 June 2023 at 6:16 pm #2209Rasmus Valerius Reck LarsenParticipantHi John do you know when the buddy tracking feature will be part is the beta? Or is it still too soon to say.
7 June 2023 at 6:48 pm #2210João PereiraKeymasterHello John Pleased make the weather Button configurable, so one can choose the weather App of choice
This is being replaced by our own weather forecast (internal DMD2 code)
Ooos another, when changing from landscape to portrait the ‘loading poi this might take some time’ message comes up, even tho all poi turned off (still showing petrol stations and no gpx displayed)
You are not supposed to be able to do that… only Landscape available at the moment.
Buy Me a Coffee7 June 2023 at 6:49 pm #2211João PereiraKeymasterUnder map layers, map labels and symbols, when click the switch to disable symbols. exit, go back into menu and switch shows they are enabled again.
Found it and fixed for next update!
Thanks
Buy Me a Coffee7 June 2023 at 6:49 pm #2212João PereiraKeymasterAha! Found the settings to turn off poi and gas stations on each gpx. Should these be set as ‘off’ as default?
Those settings have been redone, they are all off by default now.
Buy Me a Coffee7 June 2023 at 6:52 pm #2213João PereiraKeymasterHi It looks like DMD2 is using a lot of power even when the screen us turned off/locked. Is it possible to make the app pause GPS when the screen is locked? Or maybe have an option where it goes to sleep when charging stops? BR Jesper
It is not, the whole Location service gets stopped when you turn off the screen (no GPS use).
How did you measure the power consumptions?apparently The keycode F5 seems to support continuous presses. The keycodes F6 and F7 don’t seem to support continuous presses. in roadbook mode When working with a PDF, pressing the button scrolls only once. You have to press the button each time. It’s a pain to press the button every time you want to look ahead in the PDF. Is this the specification? I want continuous operation just by pressing a button can you fix it? bar button galaxy tab active3 latest beta
Buy Me a Coffee7 June 2023 at 6:53 pm #2214João PereiraKeymasterDMD2 Beta 2.99920:
– GPX Manager – Settings – Auto POI new interface, more POI categories, you can drag and drop to sort (only the first 3 will show in the progress box in the map)
– Improved Track Progress calculations
– Map Themes: 3D Buildings are now transparent
– Fixed a case where the map Progress boxes were not being removed
– Fixed a case where when DMD2 is the default home and there is a Screen Lock the location service did not start
– Fixed a case of DMD-T* devices hardware keys not mapped to DMD2DMD2 Project Manager & Lead Developer
Buy Me a Coffee -
