Viewing 10 posts - 331 through 340 (of 943 total)
  • #2053
    akcsachsen
    i have the DMD-T865 Nav Tab.
    but since yesturday, i also have the 99913 version. thanks.
    p.s.
    i am still waiting for the GPX record function 🙂
    #2055
    Beta 2.99914:
    – Finished 7 Button Controller Scheme
    – Map Settings: New settings to enable or disable the Navigation dialog to select DMD2 or external app (if disabled it defaults to DMD2 always)
    – GPX Auto Load POI: You can now click on the auto loaded POIs in the map to call the POI dialog which will list all the POIs that were loaded for that GPX
    – Germany Map is now split into Germany-North and Germany-South
    – For controllers with more than 5 buttons we removed one extra click to switch between panel widgets in the Home view
    – Fixed a bug that would crash the app when you opened the POI Manager by clicking the POI button and then used the controller to browser it
    – Fixed a bug where the TOPO map was missing roads of type “Service”
    Frontplayer
    First of all: Thanks a lot for your efforts.
    “And by the way, on non Beta its the exact same map file.”
    -> well in DMD “stable” 2.77 the German Map shows with 2.1 GB – whilst the discontinued one in Beta shows 3.86GB
    Are you on a good data connection and are you sure your device has enough storage space?
    -> jip. But even when using ethernet connection the download won´t work – now only the northern part (2.09GB) just stops downloading at 48%. Southern Germany (1.57GB) downloaded well.
    Storage is plenty (around 40GB). Maybe I can try to store it on a MicroSD as an alternative? I´m not sure what might be the reason
    #2057
    sejtam
    I also have download issues. FOr several maps (Malaysia and Indonesia. Thailand etc) it just sits there after i click ‘download’ with circle spinning, but no progress at all
    I tried both via 4G and Wifi.
    #2058
    sejtam
    The battery indicator at the top left *still* does not indicating charging when I use a wireless charger (QuadLock wireless charger v3). Yes, the battery charge does increase over time, but there is no flash icon showing the state
    #2059
    Frontplayer
    “Maybe I can try to store it on a MicroSD as an alternative?”
    Alright, used a Sandisk 64GB MicroSD now. Freshly formatted and installed 29914 on the MicroSD. Germany-North Map stopped installation again at 48% (always at this point) – I´ve made a Video of this behaviour also …
    Same behaviour with Italy map which is also >2GB. Confusing…
    #2060
    Richard
    Hi John,
    I’m still waiting to get DMD2 beta licenced on my AJP 2021 tablet. A few weeks ago you made some kind of expectation that you will implement this on the Beta. Is it still on your list?
    Greeting, Richard
    #2061
    GaryR
    Isn’t the version on the AJP proprietary?
    #2062
    Richard
    On the newer models its installed by google store on a 8″tablet from Samsung. DMD2 production version has an extra function in the setting to check the licence for the device. For now I don’t see this option in the current beta.
    • This reply was modified 1 year, 6 months ago by Richard.
    #2063
    GaryR
    Ok, it was my understanding looking at the AJP site that it comes preinstalled and connects through OBD on my 23 model being built?
    • This reply was modified 1 year, 6 months ago by GaryR.
