16 May 2023 at 12:31 pm #1835João PereiraKeymaster
DMD2 beta 2.99906, Tablet Samsung active 3, home screen with a map view in a small window. If you example receive a call and end it, the map will no longer follow where you are moving. Even if you visit the large map view and return back to the home screen, the map does not move along with the drive. You need to restart DMD2 for the small Map view to move.
This should be fixed on latest version, report back if not.
Buy Me a Coffee16 May 2023 at 1:26 pm #1836ParaenduristParticipantI use the newest Version of Germany , Switzerland Both france and spain Portugal.I live in Schopfheim and do a search for Gasstations of which one IS a nearby Shell station
16 May 2023 at 2:28 pm #1837mp_ParticipantAdded a special free 30 day trial for Tripltek T93 devices (for DMD2-Edition versions sold by Thork Racing you get a lifetime license key)
For us we got that message and we don’t have a Tripltek T93 device should we worried after the 30 days?
16 May 2023 at 2:48 pm #1838João PereiraKeymasterAdded a special free 30 day trial for Tripltek T93 devices (for DMD2-Edition versions sold by Thork Racing you get a lifetime license key)
After trial time it will fetch Play Store purchases so no worries.
Buy Me a Coffee20 May 2023 at 11:03 pm #1952harupipapaParticipantin roadbook mode
Edited TRIP figures. For example, change it to 10KM.
After that, the remote control will not be accepted.
Go to the Android home screen and return to DMD to make it operable.
This also happens on TRIP1 and TRIP2.20 May 2023 at 11:15 pm #1953harupipapaParticipantin roadbook mode
If you change the display of total single decimal place, it will not be reflected unless you change to map mode etc. once.21 May 2023 at 7:18 pm #1961Ejj75ParticipantIf you example receive a call and end it, the map will no longer follow where you are moving. Even if you visit the large map view and return back to the home screen, the map does not move along with the drive. You need to restart DMD2 for the small Map view to move.
This has been fixed DMD2 version 2.999111 👍
Feature proposal:
DMD2 GPX track features were very nice in couple of day road trip 😎
“Disable map touch when locked” was very usefull feature during rain with Samsung Active 3.
Unfortunately it can enabled only in Map Screen. In the Home Screen raindrops pushed Bottom Menu buttons. Touch screen lock would be nice feature for every screen due to rain.
So far I made touch screen lock with MacroDroid application. It can be enable by manually from floating button (floating button enabled only when DMD2 is launched and foreground). There is also automatic touch lock feature option when you drive over 60 km/h (speed adjustable).
That kind of feature would be nice in DMD2 and road trip.
22 May 2023 at 12:20 pm #2004jesperParticipantHi John I bought a DMD2 licence for devices without Play Store, because I will possibly be moving to a device without Play Store in the future. I’m using the downloaded APK and not the Play Store version, but it was not possible to activate the license unless I deactivated Google Play Services. When I reactivated the Google Play Services again, the DMD2 the “Buy Plugin” box reappears and when I deactivate the Play Services, the box is gone again. I understand that directing users to buy the license outside the Play Store is probably against Googles terms, and compiling two different version (one for Play Store and one for the website) is also hassle. But is it possible to change the code, so DMD2 recognizes an activated license even though Play Services are activated? Also i noticed when I tested a HID keyboard with DMD2, it requires three button presses on the arrow key to switch between widgets on the right when the left widget is in focus and vice versa. Is there a reason for this? Couldn’t it be that when the left widget is in focus, as soon as you press KEYCODE_DPAD_UP or KEYCODE_DPAD_DOWN, it goes to the previous or the next widget page? And the same the other way around when the right widget is active. Best regards Jesper
Hi John
Going to buy the map plugin, and was wondering if I can safely buy the standalone license and be able to use it on both devices with and without Play Services in the future? Also, are you planing on adding OBD Speed to the widgets? 🙂
Best regards
Jesper- This reply was modified 1 year, 7 months ago by jesper. Reason: I wrote GPS speed but meant OBD speed
23 May 2023 at 10:14 am #2008FrontplayerParticipantHi!
Using a CI v3 with latest DMD2 beta. The German Map would not download completely. It always stops around 25%. Tried to delete Cache data of DMD2, as well as complete re-install of DMD2 with same result.Other country maps were no problem at all.
Any suggestions?
23 May 2023 at 10:21 am #2009RalphsParticipantI have the same problem, stopped working a few revisions ago, Morocco also doesnt update anymore and Portugal (around Lisbon) looks wonky with the the coast lines just being straight lines
