Viewing 10 posts - 281 through 290 (of 943 total)
  • #1739
    BareAT
    hi john…been using beta for few days…noticed, maybe you will not consider it a bug but I’ll share it and you can decide, when start navigation with dmd2 and in case there is no GPS fix, you don’t have the option for canceling the navigation…little window recalculation always popping out and only when GPS fix appears, you get the navigation menu…
    for somebody this request will be maybe strange…but i always like to check the trip route before i start the ride, so if I’m preparing the route e.g. day before in my room and there is no GPS fix, pop up window keeps going on and off and route is highlighted on the screen…I’m using it beta version on Carpe Iter v4 if this has any role in this…
    on the other hand, did you consider maybe, when on HOME screen, and on the left you have small navigation map, when press on this small map to change screen to map screen?…and this map small window, will it maybe be dependable on the current navigation app you are using or it will always be a dmd2 map?…
    …but in any case, keep up the good work, this app will change adventure riding in the future even more…
    #1773
    PineLane Rider
    Just recently I can’t keep DMD2 set as my default launcher. Everytime my Tab Active2 reboots it changes back to the default Samsung launcher. Any ideas?
    #1778
    MagnusAgren
    Been using DMD2 for some time and it has work ok except that the GPS speed and position sometimes stops working, after killing the app and starting it again it works.
    But this morning I can’t start DMD2 it keeps crashing and the Android tells me to submit feedback which I have done. I have tried to uninstall and reinstall without any success.
    Any idea what I can do?
    Edit: now it’s working again
    • This reply was modified 1 year, 7 months ago by MagnusAgren.
    #1779
    Paraendurist
    You should delete all related Data before You deinstall..Longpress on the App and delete Cash Data that might bei suff
    icient
    #1780
    Ejj75
    Been using DMD2 for some time and it has work ok except that the GPS speed and position sometimes stops working, after killing the app and starting it again it works. But this morning I can’t start DMD2 it keeps crashing and the Android tells me to submit feedback which I have done. I have tried to uninstall and reinstall without any success. Any idea what I can do?
    I have same issue.
    DMD2 was working fine last night but today it crashes when I try to open it. I have cleared all cache data, reinstalled DMD2, restarted my Samsung Active 3. DMD2 Beta 2.99904 still crashes immediately when trying to open it.
    • This reply was modified 1 year, 7 months ago by Ejj75.
    #1784
    Murphyau
    Same problem here.  DMD2 (2.99904) worked fine when I was setting up my OBD2 dongle connection this afternoon.  Now, some 3 hours later, it crashed within 10 seconds of opening.
    #1786
    PeterK
    Same to me: DMD2 Beta on a Carpe Iter crashed constantly. Went back to production version…
    #1787
    Abyss79
    Me too on my Lenovo M7 Tab.
    yesterday evening was OK, This morning once you click the icon it crash….
    Whats happend?
    Christian
    I try also with my phone and got the same problem, deleting casch data or reinstall the beta app from zero is not a solution, same error!
    • This reply was modified 1 year, 7 months ago by Abyss79.
    #1789
    BareAT
    yep…same thing…on mobile Samsung Note20 Ultra & on Carpe Iter…just crashes when try to open…yesterday working fine when navigating thru town…
    #1790
    BareAT
    update…now working on both device…
    just showing warning on downloaded maps…only one map green (Germany), all other red warning…for update
    • This reply was modified 1 year, 7 months ago by BareAT.
