Viewing 10 posts - 221 through 230 (of 943 total)
  • #1497
    Ian Denton
    DMD2 Version  2.992
    Tried the beta out on the way to work this morning and noticed the GPS Speed was misreading high.
    Speedo showing 60mph, GPS Speed showing 90mph.
    If you take into account that the speedo overreads by about 4mph I was doing 56mph, which converts to 90kph.
    DMD2 is set to imperial as the unit text was MPH, it’s as if the gps speed is not been converted from metric to imperial.
    #1499
    simaz
    When i download maps, the program is closing.
    Only if i chose Europe Region. The another region is working.
    Samsung Galaxy Active TAB 3
    Android 13
    Oe UI 5.1
    #1500
    Abyss79
    Test on the last Beta version are running every day.
    I notice that if you have ODB connected if you are following a track you will get under the progress bar the estimate left time to the last point.
    This is very good, but I notice that not always this value came up.
    If ODB is not connect there is no time
    If is connected some time you have to move between MAPS, Home and ODB in order to get the value…
    Probabily there are some condition that make the value visible or not…. do you have the same issue?
    Thanks
    Christian
    #1501
    GaryR
    Is Turn-by-turn Nav in the 2.992 beta? When I ask for Navigation it still asks me what app to use.. Answered on Discord, 2.993 will have it today!
    • This reply was modified 1 year, 8 months ago by GaryR.
    #1503
    Test on the last Beta version are running every day. I notice that if you have ODB connected if you are following a track you will get under the progress bar the estimate left time to the last point. This is very good, but I notice that not always this value came up. If ODB is not connect there is no time If is connected some time you have to move between MAPS, Home and ODB in order to get the value… Probabily there are some condition that make the value visible or not…. do you have the same issue? Thanks Christian
    The only requisite for the time value to show is that you have a valid AVERAGE speed in your trip information since that is the value used to do that calculation.
    Beta 2.993:
    – Initial Route Calculation / Navigation features (Road only for now)
    – Improved map download with route calculation necessary files
    – Fixed a bug in the roadbook session save where the last locations was not being correctly saved
    peecis
    Hi!
    will there be “odb sensors” screen back?
    I miss nice big tachometer bar 🙂
    #1505
    Ian Denton
    Tried again this morning, after soing a Clear Storage & Clear cache last night.
    GPS speed is now displaying MPH.   Must have been some left over info from the release version causing the issue
    #1507
    Abyss79
    Nice the new version…. Tomorrow I will try…
    I have 1 question and 1 issue.
    Is it possible to load a gpx and get turn by turn indication?
    The issue is about the road calculation. Is fast and it calcolate a good tout by some Times it takes secondary road to save couple of meters and don’t use the main road.
    There is no importance classification of the different road?
    Thanks for the nice job
    Christian
    #1508
    Paraendurist
    Hello John great Work to have navigation INSIDE, especially when Offroad IS working.
    Two questions
    1 how ist possible to Stop navigation and abandon the aktual Route
    2 do You Plan to integrated intermediate waypoints and a possibility to Put them Info an specified Order
    3 will IT bei possible to replan on the Screen by moving the planned Route
    #1509
    Paraendurist
    Hello John Yesterday Had my First short Tripp with dmd2.Everything worked great. I have one Point. At the Moment IT IS Not possible to reset values in the boxes on the map Page, You have to use the widget on the Homepage for that. Would IT bei possible to integrated that on all Pages where the dayly Journey values are visible. Would IT also bei possible to start the Journey manualy
