I edited my response. See ^
how to sign to have the beta on carpe iter ?
thx
Good morning. Still no improvement. Map is not moving. GPS debug shows a stopped movement and goes back to normal and so forth . I guess this is the reason. All other navigation apps are working just normal.
I am on 2.88.
regards Thomas
Good morning. Still no improvement. Map is not moving. GPS debug shows a stopped movement and goes back to normal and so forth . I guess this is the reason. All other navigation apps are working just normal. I am on 2.88. regards Thomas
Let me guess its an Active Tab 2?
I did uninstall first. Installed fresh. Was 2.87. I started DMD2, it asked for update. I confirmed. Went into Settings … version still 2.87. I guess it is 2.88 now, but showing wrong/old version number?
Tried the update process on my Garmin Tread and it updated perfectly to 2.88, if I go to DMD2 global settings and scroll down it reports 2.88 installed.
It did the same just now. Thanks.
No, Blackview BV5200pro
The battery icon at the top left could use a modification that shows when the phone is charging
I tried connecting to my OBDLikMX+ today. but it was very intermittent. AT the beginning it seemed to cycle through all protocols continuously, sometimes showing RPMs etc for a few seconds, then it switched to another protocol/setting etc. and it never stopped doing that., nor is there an indication which protocol setting worked when, so that one could fix them and not have to live through that every time.
It would be useful to have log showing with what protocol/settings it worked best and/or what did not work
Hello I just figured out that if I keep the phone in the hand while driving and move it a bit the map will follow instandly without any interruptions. If I place the phone on the seat and car is driving smooth it stops working. Picking it up again and move a bit map is moving again. In the debug mode I can verify this behavior. As long I am shaking a bit (should drink more beer) the phone the movement is detected and it works. So driving on the motorway without bumps might stop the map moving. Hope this info helps.
Thomas
