Viewing 10 posts - 1 through 10 (of 10 total)
  • #35959
    ivan
    Salve,  sono un nuovo utilizzatore di dmd2 (t665+tpms) non so ancora bene come funziona questo mondo perciò chiedo aiuto a voi.          sul sito thork racing nella descrizione del t665 è indicato Android 14, utilizzo il mio t665 da circa 10 giorni con android 12 e non vedo aggiornamenti, qualcuno sa darmi spiegazioni in merito e cosa devo fare? Grazie
    #35960
    sonwon
    Translated from Google.
    Hi, I’m a new user of dmd2 (t665 tpms) I don’t know how this world works yet so I ask you for help. On the thork racing website in the description of the t665 it says Android 14, I’ve been using my t665 for about 10 days with android 12 and I don’t see any updates, can anyone give me explanations about this and what I should do? Thanks
    #35966
    TR42
    Tienes el menú de Ajustes de DMD, que es el icono del engranaje en la parte inferior de la pantalla. También tienes el menú de Ajustes de Android para Tabletas/Teléfonos. En la parte inferior de la pantalla, pulsa el icono de las 4 casillas. Luego, pulsa el icono de Ajustes, desplázate hasta abajo y pulsa “Acerca del dispositivo”. Desplázate hasta el Modelo T665; justo debajo verás “Versión de Android” y pulsa esa opción. En la siguiente pantalla, pulsa “Actualización del sistema 12”. Debería buscar una actualización.
    Asegúrate de tener una tarjeta SIM en el dispositivo o de que esté conectado a una red wifi.
    You have the DMD Settings menu, which is the gear icon at the bottom of the screen, then you also have the Tablet/Phones Android Settings menu. At the bottom of the screen, tap the 4 Boxes Icon. Then tap the Settings icon, scroll all the way down to, tap on “About Device”. Scroll down to Model T665, just below that you see “Android Version”, tap that.  Then on the next screen tap System Update 12. It should search for for an update.
    Make sure you either have a SIM card in the device or it’s connected to WiFi first.
    #35973
    ivan
    Hi tr42 thanks for the advice, I had already tried this solution but without results.
    #35974
    TR42
    Entonces, ¿está diciendo que encontró y ejecutó el cuadro de diálogo Actualizar pero su dispositivo indicó que no encontró una actualización?
    So, are you saying that you found and ran the Update dialog but your device stated that it did not find an update?
    #35975
    ivan
    Yes
    #35989
    TR42
    Then I’d say this is a problem only The Man himself can answer. Paging Joao.
    #35991
    ivan
    who is joao?
    #36002
    TR42
    João Pereira. He’s the Admin of this forum.
    #36005
    ivan
    Thank you
